jameskett
posted on 20/12/15 at 08:44 PM |
swirl pot plumbing
My Fury had a swirl pot added at some point before I got it , I'm refreshing all the rubber fuel hoses at the moment and the swirl pot plumbing
doesn't seem quite right.
The car has Jenvey TBs with a fuel regulator connected to the TB rear fuel-rail outlet.
At the moment it has:
- top pipe - fuel IN from regulator bottom pipe (return from TBs)
- upper middle pipe - fuel IN from LP pump / tank
- lower middle pipe - fuel OUT return to tank
- bottom pipe - fuel OUT to filter -> HP pump -> throttle bodies inlet
So from what I can tell that's not right - it should be like this:
http://www.locostbuilders.co.uk/gallery/a603118-5.jpg
but I'm not sure if all swirl pots are the same inside? It's a nice alloy one but doesn't have any markings / manufacturer name on
it. Are they just an empty pot with 4 outlets?
thanks
James
mark chandler
posted on 20/12/15 at 09:29 PM |
Fuel back to the tank always at the top as its overflow.
HP always feeds from the bottom
Fuel supply from the LP pump and from the rail return into the middle, it does not really matter which one, they should both come in at an angle to
promote swirl.
In the end I dumped my swirl pot and built a sump and baffles into the fuel tank for simplicity.
Regards Mark
[Edited on 20/12/15 by mark chandler]
ken555
posted on 20/12/15 at 09:48 PM |
jameskett
posted on 21/12/15 at 09:09 AM |
Thanks, looks like it was wrong before - seeing as all the hoses end up at the pot at least its an easy fix
907
posted on 21/12/15 at 09:10 AM |
As the others have said, inlets and outlets enter and exit as tangents.
Personally if I had the inlet on the left then the outlet would be on the right ( as "p & q" )
so both encourage a vortex in the same direction.
Paul G
[Edited on 21/12/15 by 907]
jameskett
posted on 21/12/15 at 03:36 PM |
both side pipes are on the same side , same as that image above only mirrored.
