rotax78
posted on 20/12/15 at 08:48 PM |
Tilting car lift
![](/galpreviews/20151220_151622.jpg) ![Description](/gallery/20151220_151622.jpg) Description
![](/galpreviews/20151220_151438.jpg) ![Description](/gallery/20151220_151438.jpg) Description
You've all seen these before, turn the handle or use a drill and it goes up and down, give it a shove and it tilts backwards and forwards. In
Hyde, Cheshire, SK14 £275.
[Edited on 20/12/15 by rotax78]
hizzi
posted on 20/12/15 at 09:00 PM |
been seriously looking at one of these for my haynes roadster, have you had your car on this or just normal cars?
would it fit on a pallet and would you send it?
rotax78
posted on 20/12/15 at 10:13 PM |
I don't have the MK anymore so I don't know. The overall dimensions are approx 1300mm x 1500mm. The approx distance between the sill
plates is 1190mm (inside to inside) and approx 1540mm (outside to ouside) when folded flat it stands approx 150mm high. It has a capacity of 1500kg. I
really wanted it collected, maybe drop off if local.
froggy
posted on 20/12/15 at 11:05 PM |
It's too wide for a seven but I bought one and cut 12" out of the frame which was an hours work so it fits both my cars .
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
posted on 21/12/15 at 01:21 PM |
Always managed fine with a low trolley jack and axle stands with my MK Indy.
ETA...maybe because I already had them to hand though.
[Edited on 21/12/15 by nick205]
froggy
posted on 21/12/15 at 02:19 PM |
When I do my yearly waxoyl touch up on the kitten I tilt it fully each way and sit on a little mechanics stool with a pot and brush . No more waxoyl
in the face
posted on 22/12/15 at 09:06 AM |
in the face
Now that reminds me of the tale posted some time ago about a Land Rover nut Waxoyling his pride whilst SWMBO was out. I recall he got Waxoyl
everywhere including all over the cat.
