Author: Subject: CLEAROUT...brakes, silencer, lights, bits and bobs
b3ngy
posted on 4/2/16 at 09:59 PM Reply With Quote
Full Sierra front brake kit. Comprising of calipers (recently painted in black vht paint and laquer) fitted with mintex 1144 fast road/track pads, vented discs and braided lines (not pictured) to suit. £75 collection would be ideal as postage will be quite expensive however happy to post at buyers expense.
[img] Description
[/img]
[img] Description
[/img]
[img] Description
[/img]
[img] Description
[/img]
Wilwood Powerlite smartpad P/N 150-8813. £18.50 posted
[img] Description
[/img]
Sierra rear mintex pads MDB1287. Covered approx 500 miles. £8 posted
[img] Description
[/img]
Stainless steel silencer (repackable). Overall length 32.75”. Silencer length 21.5”. Diameter 5.5”. Attachment pipe 2.5”. £60 posted SOLD
[img] Description
[/img]
FAE 37410 radiator temp sensor 102/93 switching points. M22x1.5. £4 posted
[img] Description
[/img]
Rear number plate light. £3 posted
[img] Description
[/img]
Battery clamp. £3 posted SOLD
[img] Description
[/img]
Herringbone edge trim (ideal for IVA) 1x1.2m length and 2x1.77m lengths plus various short offcuts. 14mm tall, will grip 0.5mm – 3mm thick material. £7.50 posted SOLD
[img] Description
[/img]
Pipercross PX500 baseplate to suit Hayabusa throttle bodies. £25 posted SOLD
[img] Description
[/img]
Remote clutch reservoir with 10mm push – on fitting £7 posted
[img] Description
[/img]
Wipac 95mm red light E11 marked with mounting housing. £7 posted
[img] Description
[/img]
[img] Description
[/img]
Pair of 7” chrome headlights. A small amount of rust spots on the underside. £35 posted SOLD
[img] Description
[/img]
[img] Description
[/img]
[img] Description
[/img]
Oil pipe made by ThinkAutomotive, never used. -8JIC 90deg female one end and ½”BSP 90deg female the other end. Swaged fittings. Approx 58 cm long. £18.50 posted
[img] Description
[/img]
Stainless steel overbraid 1x2m length and 1x4m length. Will fit hose upto 21mm external diameter. £30 posted
[img] Description
[/img]
Wilwood master cylinder 0.625 with integral reservoir. £18 posted SOLD
[img] Description
[/img]
Accusump electric valve £50 posted
[img] Description
[/img]
[img] Description
[/img]
Clutch master cylinder bracket complete with linkage. Ideal if you want to use a motorbike rear brake master cylinder. Not sure if the master cylinder fitted is any good. It worked fine when it was removed a couple of years ago. £10 posted
[img] Description
[/img]
[img] Description
[/img]
Cosmic universal fitment wheel spacers set of 4 (5mm thick) £12 posted SOLD
[img] Description
[/img
[Edited on 5/2/16 by b3ngy]
[Edited on 6/2/16 by b3ngy]
RedAvon
posted on 5/2/16 at 12:13 AM Reply With Quote
Could I have the master cylinder, edge trim and battery c!amp please?
Ian
Bricoleur
b3ngy
posted on 5/2/16 at 07:15 AM Reply With Quote
No problem Ian. I'll package it up later and get a combined postage cost. I'll u2u a total later on.
steve-hv8
posted on 5/2/16 at 07:18 AM Reply With Quote
I'll take the headlights off you
Tell me where to send payment
Regards
b3ngy
posted on 5/2/16 at 09:58 AM Reply With Quote
Steve u2u sent
steve-hv8
posted on 5/2/16 at 06:19 PM Reply With Quote
Payment sent
Zetecron
posted on 6/2/16 at 01:52 PM Reply With Quote
Silencer
Hi there, away home to measure up my Striker for silencer. You know what make it is? Looks clean, any dents or scratches?
b3ngy
posted on 6/2/16 at 05:18 PM Reply With Quote
No idea what make it is. Condition wise there are some scratches on the underside and also a mark on the inboard side where the old mounting bracket was welded on. You can't see any of this once mounted. No dents.
