Author: Subject: Atlas axle bolt on brake caliper kit
locost 7 k
posted on 11/3/16 at 12:04 PM Reply With Quote
Hello, I've got a 2.0 capri atlas axle on drums but I'd like a bolt on kit that allows me to run disc brakes
Ideally I'd like a set of wilwoods or similar (4 pots)
Are there any kits out there?
Many thanks
Jon Ison
posted on 11/3/16 at 12:55 PM Reply With Quote
I welded two tabs on, used "heavy" Sierra calliper sand fiesta discs, 13" wheels just sneak on.
locost 7 k
posted on 11/3/16 at 02:32 PM Reply With Quote
I think that's probably the route I'll have to go
Benzo
posted on 11/3/16 at 05:21 PM Reply With Quote
Do you want or need a handbrake on the car?
hizzi
posted on 11/3/16 at 07:23 PM Reply With Quote
ive seen the stockcar guys with f2 do this someone must make them. try mcgill motorsports
Volvorsport
posted on 11/3/16 at 07:31 PM Reply With Quote
Rally design. .. xr3i discs iirc
www.dbsmotorsport.co.uk
getting dirty under a bus
RichieW
posted on 11/3/16 at 07:36 PM Reply With Quote
Four pot Wilwoods on the rear??
locost 7 k
posted on 11/3/16 at 07:49 PM Reply With Quote
Thanks for the replys
Yeah I'll need handbrake, it'll be for the road
The car will be fitted with a hydraulic e-brake and used for drifting so 4 pot's should make it feel more sharp
Benzo
posted on 11/3/16 at 08:10 PM Reply With Quote
Do Wilwood do a mechanical handbrake 4pot? For mot purposes?
locost 7 k
posted on 11/3/16 at 08:12 PM Reply With Quote
If not then I'll have to get there handbrake only caliper
