Author: Subject: Ultra low entry scissor action jack for my Radical
carpmart
posted on 13/3/16 at 09:49 PM Reply With Quote
anyone got one or seen one FS please?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
JacksAvon
posted on 13/3/16 at 10:23 PM Reply With Quote
one of these?
quick lift jack
The sickness started in 2001 with a Robin Hood 3A, Prelit Westy,Tiger Cub, Tiger Avon, Tiger R6, 16v Mini, Sylva Fury Fireblade, Westfield Sei, Mallock Mk11, Fireblade Locost, Tiger Avon, Procomp LA Gold, Mk26 Mallock...........and now a Mk18 Mallock.....LR750, Vandiemen FX02
daniel mason
I used to push it onto a 1" battern then up onto a 4" x 2" then a standard long reach quick jack works fine. The rear is easy to jack up with stsndard quick jack
daniel mason
posted on 13/3/16 at 10:24 PM Reply With Quote
That 50mm jack wouldn't have gone under mine. I only had 40mm ground clearance
[Edited on 13/3/16 by daniel mason]
Dopdog
posted on 13/3/16 at 10:32 PM Reply With Quote
I like the way he says he can do it at a lower price than others
and as you say Dan it will not go under our cars
daniel mason
posted on 13/3/16 at 10:50 PM Reply With Quote
Radicals are worse than single seaters to jack up at the front. The front body overhang is quite severe! You really need the front wheels on some wood.
Brook_lands
posted on 14/3/16 at 07:54 AM Reply With Quote
We use this sort of thing
http://www.demon-tweeks.co.uk/motorsport/rally-accessories/race-ramps-trak-jax-jack-clearance-ramps
Quite easy to make your own to suit if you want to go Locost.
HowardB
posted on 14/3/16 at 08:15 AM Reply With Quote
I made one,... I guess it can be adjusted to suit,...
locost low jack
locost low jack
or can you make an adaptor to use something like the rally jacks? Or a tip over one like they use in F1?
hth
Howard
daniel mason
posted on 14/3/16 at 08:31 AM Reply With Quote
I have a set of those ramps like Brookland. But the prosport wouldn't even go up them without being on battern
gaz_gaz
I used this with my Radical
http://www.adr-engineering.co.uk/shop-list-item.php?item=113&shop=Racing&time=1421961050
carpmart
posted on 15/3/16 at 11:01 AM Reply With Quote
Thanks for all the replies chaps..
I've got a set of shallow angle ramps I roll it onto, but just wanted something a little easier to use and more 'elegant'.
'94 MX5 MK1, 1.8
Johneturbo
posted on 17/9/18 at 11:19 AM Reply With Quote
locost low jack
locost low jack
hth
I know it's an old thread but been searching for something like this, as the only way i can jack the car up is rolling it on blocks of wood as the MNR nose cone protrudes a long way forward.
Howard how low is the jack? and how much travel do you have?
[Edited on 17/9/18 by Johneturbo]
HowardB
posted on 17/9/18 at 11:30 AM Reply With Quote
If you are using the very front then 20mm, other wise depends on the size of the rollers/wheels, 40mm should be possible. It goes "over centre" so the lift height is just less than the length of the front arms, I have about 200mm on mine, enough in most cases.
Howard
Johneturbo
posted on 17/9/18 at 01:58 PM Reply With Quote
Yes 200mm would be plenty
Do you have a diagram on measurements ect as I would like to build something like this
HowardB
posted on 17/9/18 at 02:02 PM Reply With Quote
I did have a set of drawings for it, I have changed PC a few times since, I'll see if I can find it. u2u me your email and I'll send what I can or take some more pics...
Howard
Johneturbo
posted on 17/9/18 at 03:01 PM Reply With Quote
Cool, cheers I'll send you my email
