Just to add this is a Geartronics pneumatic system and as you can see the clutch is still engaged (no one in the car). So when driving this is
clutchless and full throttle shifts. with a blip on the downchange.
There is a compressor & accumulator under the passenger seat. Slightly heavier solution than the bottle (1-1.5Kg) but it means I don't have
to drag a very large air bottle around with me in the RR.
[Edited on 16/5/16 by jeffw]
And as a passenger you get quite a buzz coming up from it! Maybe that was why Debbie was screaming
quote:Originally posted by adithorp
I was surprised at Llandow that I could hear the gear change air puff from trackside.... Even with all the other super charger related noises.
It is possible there is an air-leak somewhere but I think it is normal.
