Author: Subject: can anyone on here water jet or laser cut 30mm steel
emsfactory
posted on 12/6/16 at 07:28 PM Reply With Quote
Hi all.
A chap at work is building a sled puller and needs a plate making up for his bellhousing.
It needs to be 30mm thick, probably steel, approx 500mm x 500mm.
He does not have a drawing but a metal template.
Ideally the holes would be in it too.
Any takers or idea where?
Cheers.
daviep
posted on 12/6/16 at 07:55 PM Reply With Quote
Where about in the country?
Davie
marc_cowley
posted on 12/6/16 at 08:01 PM Reply With Quote
I just had a plate cut here http://www.h2ocreations.co.uk/
absolutely spot on
C30 T5
emsfactory
posted on 13/6/16 at 05:23 AM Reply With Quote
He is in Aberdeenshire
posted on 13/6/16 at 07:58 AM Reply With Quote
Other end of the country (in Hampshire), but have a local supplier (Portsmouth) who could do this for you from a drawing and deliver it.
Let me know if that helps and U2U me for contact details.
Nick
Slater
posted on 13/6/16 at 08:54 AM Reply With Quote
Try these guys based in Oldmeldrum Aberdeenshire
http://www.poseidonengineering.com/
harmchar
posted on 14/6/16 at 09:35 AM Reply With Quote
There is also Whittaker engineering in Stonehaven. Won't be free, but will be well done.
