tegwin
posted on 13/7/16 at 04:39 PM |
Any of you have a router suitable for carbon sheet?
Any of you clever chaps have a router/waterjet cutter capable of cutting up to 3mm carbon fiber sheet? I have a pile of drone spares so I want to make
a frame to utilize the spare parts
Can provide the cad file if anyone can cut?
www.verticalhorizonsmedia.tv
twybrow
posted on 13/7/16 at 05:33 PM |
Why not diy with a hacksaw or disc cutter? You would finish the edge by sanding anyway. 3mm is nothing tricky.
tegwin
posted on 13/7/16 at 05:39 PM |
have you ever tried to manually cut complex shapes accurately out of carbon fiber sheet? Its not going to happen!
Neville Jones
posted on 13/7/16 at 05:47 PM |
What are the max dimensions of what you want cut?
My son's up in Tavistock, has a small cnc mill that does work for me.
tegwin
posted on 13/7/16 at 05:55 PM |
The largest panel is 206x160mm. Not finished the detail design yet but it should only be two pieces that size and a few small bits.
Smallest internal radius is 3mm. Smallest hole is 3mm.
bi22le
posted on 13/7/16 at 07:40 PM |
Sounds quite intricate otherwise i would of suggested a coping saw.
I did this a fair few times when I was a kid smashing up RC cars. Then just drill the holes you need after.
Please read my ring story:
twybrow
posted on 13/7/16 at 08:02 PM |
Yes, a fair few times. Chain drilling, cutting and sanding can give good results, but i appreciate a cnc router is a good option.
posted on 14/7/16 at 08:07 AM |
There's a waterjet cutting place in Estover, might be worth getting a quote?
[Edited on 14/7/16 by MikeRJ]
