silky16v
posted on 26/7/16 at 01:51 PM |
Audi C5 RS6 Avant 2003
Hi all,
I've thought on this long and hard, and as much as I expected to keep this car for a great deal of time, I just can’t justify having 3
vehicles.
C5 RS6 Avant 4.2 V8 Biturbo Quattro tiptronic
First registered 31.07.2003,
"03" registered,
108000 miles,
MOT 24.09.16.
Factory specification:
Extras:
Mugello Blue pearl effect paint
Valcona leather - Silver - comes with Alcantara headlining to ceiling - silver colour
Privacy glass
Solar panel sunroof
Inlays to dash & doors - Poplar Agate veneer - grey
Cross drilled brake discs
19" x 9J 5 arm design alloy wheels
Standard:
Recaro sports front seats with electric adjustment, RS6 embossing to leather on front and rear seats
Electrically adjustable steering column with convenience entry / exit feature
Heated front and outer rear seats
Front centre armrest
Rear armrest
One x front and two x rear cupholders
BOSE 250 watt premium sound system
Radio navigation system, analogue TV reception, 6CD changer
Driver's information system
Cruise control
Electrical folding door mirrors
Automatically dimming interior rear view mirror
Usual central locking and windows.
Maintenance:
Full Audi service history:
1. 9458 miles, Hartwell Audi, 10.12.2003
2. 25169 miles, Warrington Audi, 11.10.2004
3. 40197 miles, Warrington Audi, 25.05.2005
4. 54334 miles, Warrington Audi, 09.12.2006
5. 65857 miles, Warrington Audi, 26.01.2007
6. 72550 miles, Lake District Audi, 09.01.2008
7. Cam belt change done by Ian Collins Automotive, Billsborough, Preston, 02.06.2008
9. Gearbox rebuild by A1 premier transmissions of Biggleswade, 06.02.2009 at 80482 miles.
10. 80760 miles, Carlisle Audi, 28.02.2009
11. DRC replaced with H&R coil overs and Hotchkiss ARBs, Stage 1 map and TCU map, Unit20, 10.03.2009
12. 86100 miles, Carlisle Audi, 10.02.2010
13. NSR brake calliper replaced with new item due to seizing - 26.11.2010
Some low life member of society scuffed my OSF wing, headlight and bumper on 23rd December 2010. They drove off without leaving a note. My insurance
company would only offer to pay to re paint this localised area and replace the scuffed OSF headlight unit (leaving the 7 years of stone chips visible
elsewhere).
Naturally I would not have been pleased with this outcome, so I later paid the local Audi approved bodyshop to repaint the front of the car, being
sympathetic to the age of the rest of the car (I didn't want the sides of the car painted without reason). Therefore - the front bumper and
bonnet were repainted, along with the front wings being colour painted to around the area of the side repeater indicators. The whole area of the wings
was lacquered, and this has worked very well. Original paint everywhere except these areas - looks fabulous.
14. 91980 miles, Carlisle Audi, 20.04.2011, Gearbox service, transmission sump and secondary air injection system pipes replaced, Unit 20
15. Paint repairs to front end - Bendalls bodyshop, Carlisle, August 2011.
16. 95253 miles, Cam belt change along with water pump, thermostat, tensioners. Carlisle Audi, 07.07.2012
17. 100359 miles, Carlisle Audi, Inspection 14.10.2013
18. 101915 miles, Carlisle Audi, Oil & Filter 20.09.2014
19. 102485 miles, Carlisle Audi, Oil & Filter, Front upper arms & C-Links replaced & front lower arms & 4 wheel alignment
20.05.2015
The car also has the following desirable modifications / extras:
Stage one "CustomCode" map installed along with transmission ECU map at Unit 20.
Genuine Audi rigid load liner in boot, installed from new, still with anti-slip mat. Hence boot floor under this looks like new!
RNS-E navigation unit installed with 2009 maps. 2 x SD card reader for MP3 playback. Still links to functioning 6CD changer, however TV reception no
longer plumbed in (makes no difference as it was defunct analogue anyway). Makes such a difference to the interior - more modern and essentially the
same OS as many of the newer cars on the Audi range today.
AUX input discretely added to glove compartment - added by Craig Barnes giving music playback from iPod or similar.
The above information was from the previous Owner and I’m sure he won’t mind me mentioning that he works for Carlisle Audi and had owned the car since
2008 it was his pride and joy and if the car needed anything it went through the Audi workshop or to Unit20 (the list of history is the best I’ve ever
seen)
Since I have owned the car (Dec 2015) I have continued with its maintenance and upgraded some parts to my liking in my ownership it has had the
following:
• Genuine F125 Gearbox switch 12.01.16
• LED lighting upgrade and RS6 logo’s in both front door puddle lights 25.01.16
• Engine temp sensor 28.01.16
• New Zimmerman drilled front discs and Ferodo DS2500 pads, new calipers pins and sliders (done 2500 miles) 23.05.16
• 4x Pirelli p-zero nero 255/35/19 tyres and wheels powder coated anthracite metallic grey 10.05.16
• Front outer CV boots replaced 18.05.16
• New Pagid OEM spec rear pads and rear calipers dismantled, sliders and seals replaced that were worn 13.06.16
• Rear discs remove and cleaned up on a lath and all holes re-drilled to clear out old pad material 13.06.16
• New N75 and DV’s Genuine Bosch MAF’s 20.05.16
• Vacuum pipes all replaced with silicone hoses
• Full service using Genuine parts, air filters, pollen filter, fuel filter, oil and oil filter
• The wheels were sent for blasting and powder coated anthracite metallic grey and brand new Pirelli P-Zero Nero tyres fitted 255/35/19
• I’ve had the rear Backboxes removed and Stainless 2.5” Straight pipes with new 6” oval tips this joins the stock system just after the centre
resonators (originals still available)
• Car has had a full detail from MP Autodetailing and Dodo juice wax applied but in all honesty the previous owner had already spent a lots of time
applying zymol titanium wax to the body and glass and water just beads off the cars
• Front bumper grill has been painted Matte black to match the intercooler intake plastics
I have done over 5000 miles in the car since December and it has been nothing but enjoyable and been a pleasure to drive.
And the only reason I’m selling is that shortly after buying the car I also bought an Audi S1 from Carlisle Audi to use as my daily and as much as I
love the S1 I don’t want to use it as my everyday car
So purchased a VW caddy van to use for work, thus now meaning I have 3 cars. The caddy ticks all the right boxes for my work requirement and to take
the dog in occasionally
The S1 will become my weekend car and then it leaves the RS6 sadly not being used which is the worst thing for them to stand idle!
I have just returned from taking the car to Unit20 (01.07.16) for a full health check and the following:
• Full health check (no issues and error free)
• Change all the diff oil, rear, centre and front checked
• New MAF seals on the inlet manifold
• RS6 gearbox service
So this is an RS6 wanting for nothing, everything has been done to it ready for a new owner and I truly believe you would be hard pushed to find a
better condition and well maintained C5 RS6 for the money.
I would prefer it be sold to a forum member who will look after it as I have. I can honestly say that although I will have driven it fast on the odd
occasion, I've never abused it and this car is genuinely well kept.
I would say without being big headed that this will be one of the most presentable C5s available, so immaculate is it in appearance.
Price is £11,000 o.v.n.o (I don’t want any p/x or swaps)
The vehicle is located in North West Cumbria & also has a Tracker fitted which is transferable to the new owner
![](http://www.sierracosworth.co.uk/forsale/RS6/interior3.jpg)
jeffw
posted on 26/7/16 at 03:20 PM |
Looks lovely, it will have been well looked after by Grizz at Unit 20.
Fandango
posted on 26/7/16 at 06:38 PM |
Looks great.
I was thinking about getting one of these a few years back, but ended up with the "semi skimmed" S6.
Still a slightly unscratched itch!
Anyway, with the superb history, gearbox rebuild, and coilovers, I reckon it will easily go at that price.
Good luck.
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me." Hunter S Thompson
silky16v
posted on 27/7/16 at 06:12 PM |
quote: Originally posted by Fandango
Looks great.
Good luck.
Thanks good ones are very hard to come by now tbh I looked for 6 months before buying this one
