Author: Subject: MX5 build - Clutch switch / custom ecu
dwebber597
posted on 17/8/16 at 10:21 PM Reply With Quote
Im building my Locost using an mx5 donor. If i use a custom ecu (Megasquirt or similar) would i need to wire the clutch pedal switch to the custom ecu? or is the clutch switch purely for the mx5 ecu's benefit?
coyoteboy
posted on 18/8/16 at 12:53 AM Reply With Quote
You could do, in order to get launch control and flat shifting, but there's no requirement for a clutch switch to run an engine.
coyoteboy
posted on 18/8/16 at 12:54 AM Reply With Quote
dwebber597
posted on 18/8/16 at 02:02 AM Reply With Quote
Thanks coyoteboy. That could make the build a bit neater
garyt
posted on 20/8/16 at 07:30 PM Reply With Quote
While your at it there is a neutral switch on the side of the gearbox and if using the std ecu it gives an "anti stall" function to the ecu which revs the engine slightly when you pic it in gear. I earth said wire so no issue (2003) ecu although some others reported the same
remember we are not mad just creatively insane !!!!!
