Author: Subject: Weber DGV 32/36 manual choke adjustment?
posted on 9/9/16 at 01:57 PM Reply With Quote
Can anyone tell me the correct way to set up the manual choke on this carb? All I can find on-line are instructions for automatic chokes, both electric and water-based, and they say that when cold, the choke butterflies should be open a little bit (usually measured with the shank of a drill bit).
My choke plates shut completely, but are spring loaded - I presume that the flow of incoming air opens them up. In reality, if I pull the choke far enough to get the advanced throttle coming on, I get way too much choke. If I push the choke back so that the mixture is right for a cold start, the advanced throttle is off and I'm having to blip the accelerator pedal to keep the thing alive. Basically, it needs adjusting but I have no idea how to do it...
Any help or clues will be appreciated!
theduck
posted on 9/9/16 at 03:20 PM Reply With Quote
Are you sure its jetted correctly?
907
posted on 9/9/16 at 04:38 PM Reply With Quote
O dear.
Gold coins changed hands to get the jets set, allegedly.
theduck
posted on 9/9/16 at 04:57 PM Reply With Quote
Just sounds to me like its jetted too rich.
posted on 9/9/16 at 05:12 PM Reply With Quote
Once it's warmed up it runs very well, and idles properly - it's just the choke that's a PITA.
AndyGT
posted on 9/9/16 at 08:15 PM Reply With Quote
do you not have the Haynes manual for Escort mk2?
nothing is impossible
everything is possible
Dingz
posted on 9/9/16 at 10:24 PM Reply With Quote
On the Auto choke versions, there is a fast idle adjustment screw which runs on a cam connected to the choke mechanism, is there not something similar on yours?
went on and on.
posted on 10/9/16 at 12:33 PM Reply With Quote
AndyGT - I do have a Haynes manual, but it only describes the auto-choke version of this carb. The same goes for the Wallage X-flow book.
Dingz - no fast idle screw on my carb - in fact, there's no obvious adjustment apart from the idle mixture and idle speed screws (which are set OK for normal running).
