Author: Subject: Coilovers
Banana
posted on 12/9/16 at 09:51 PM Reply With Quote
Coilovers
Im after a set of coilvers suitable for an IndyBlade.
Or just a pair would do for the time being, as its only the rears leaking.
thanks
Shooter63
posted on 13/9/16 at 05:30 PM Reply With Quote
Not being au fait with indyblades what length dampers do you need, I've got 2 pairs of gaz under the work bench not doing anything.
Shooter
Banana
posted on 13/9/16 at 08:41 PM Reply With Quote
Thanks, i will try and get dimensions tommoro.
Its a 2004 Indy with IRS - if that anyone else reading this can assist with dimensions..?
I only mention the fact i was a BEC, due to the reduce weight.
andygfc
posted on 14/9/16 at 06:07 AM Reply With Quote
Gaz
If the shocks are no good for banana, I'm after a set for a locost
[Edited on 14/9/16 by andygfc]
Banana
posted on 14/9/16 at 11:43 AM Reply With Quote
Thanks!
How do the gaz measure up shooter?
procomp
posted on 14/9/16 at 01:05 PM Reply With Quote
Hi. Ill U2U re Gaz dampers.
Cheers Matt
Shooter63
posted on 14/9/16 at 06:25 PM Reply With Quote
Sorry guys,
1 pair are 11" and one pair are 15"
Shooter
Banana
posted on 14/9/16 at 09:09 PM Reply With Quote
Thanks anyway -
Anybody else?
Banana
posted on 17/9/16 at 03:35 PM Reply With Quote
Bump
