Author: Subject: Zetec starter
Hammy360
posted on 22/9/16 at 03:35 PM Reply With Quote
Zetec starter
Hi all,
Im fitting blacktop 2.0 Zetec to a type 9 with retroford flywheel and pinto clutch.
Does anyone know which starter I need, I believe its sierra 2.0 DOHC but can't remember.
Hammy
AndyW
posted on 22/9/16 at 04:19 PM Reply With Quote
I used a Lucas LRS707
Not sure about the flywheel though as I used standard one.
I got one of ebay brand new and was much cheaper than the kit suppliers. Works find and still going strong.
Hammy360
posted on 22/9/16 at 04:50 PM Reply With Quote
Hi mate,
Thought so, like this one?
FORD SIERRA & SAPPHIRE 2.0 PINTO OHC & DOHC NEW RMFD STARTER MOTOR 1987-93
Hammy
AndyW
posted on 22/9/16 at 04:53 PM Reply With Quote
FORD 87BB11000BA
FORD 87BB11000DA
looks like it to me. The above are the ford part numbers and cross ref to that one so looks good to go.
Hammy360
posted on 22/9/16 at 05:37 PM Reply With Quote
cheers
Originally posted by AndyW
FORD 87BB11000BA
FORD 87BB11000DA
Lovely thats what I thought as my donor for my last build was sierra 2.0 dohc and I was sure I used the starter from that.
PS. Andy, I'll let you know how the conversion is going when I get some time in the garage!
Blogs is here mate http://zetecstriker.blogspot.co.uk/
Hammy
obfripper
posted on 22/9/16 at 06:24 PM Reply With Quote
Originally posted by Hammy360
Hi mate,
That one needs a 14mm spacer to correctly engage the flywheel, it does cross reference but is incorrect for this application without a spacer.
You need one of these for a direct fit:
http://www.woodauto.com/Component.aspx?Ref=STR50041
It has the shorter nose, and the linked one has planet reduction gears so smaller than the original lucas type and far more powerful (should be fine cranking a hot engine).
Dave
Hammy360
posted on 22/9/16 at 07:49 PM Reply With Quote
Hi mate,
Dave
Cheers, thanks
Hammy
Hammy360
posted on 5/12/16 at 01:19 PM Reply With Quote
Hi mate,
Dave
Hi mate, can I just confirm again I have a retroford flywheel and pinto clutch http://www.retro-ford.co.uk/shop/content/zetec-rwd-flywheel-z015
Just want to triple check before ordering as the retroford starter is 120!
Cheers for your help
Hammy
loggyboy
posted on 5/12/16 at 01:23 PM Reply With Quote
have you tried asking retro ford?
Mistral Motorsport
Hammy360
posted on 5/12/16 at 01:30 PM Reply With Quote
Yes mate, they obviously said their one :-)
Hammy
obfripper
posted on 5/12/16 at 02:10 PM Reply With Quote
The retroford flywheel is a pinto clutch pattern redrilled 1.8 zetec flywheel, so that starter should be fine.
Dave
Hammy360
posted on 5/12/16 at 02:44 PM Reply With Quote
Dave
Thanks mate, ordered at a big saving :-)
Hammy
