Author: Subject: Best "Glue"
AndyW
posted on 22/9/16 at 06:06 PM Reply With Quote
Best "Glue"
Hi
I have had the magnet come off my prop again. I have tried various fixing methods all to a clean bare metal surface but time and time again it comes off. Been about 5 times now.
So, what is the best glue/adhesive to attach it for a longer period?
ragindave
posted on 22/9/16 at 06:24 PM Reply With Quote
Would Tiger Seal PU adhesive not do it?
mark chandler
posted on 22/9/16 at 06:31 PM Reply With Quote
I tried various glues, araldite etc and they all flew off, a propshaft at 6000rpm will throw off most things, my pickup is now on the rear halfshaft.
[Edited on 22/9/16 by mark chandler]
chris_smith
posted on 22/9/16 at 06:47 PM Reply With Quote
Can you not fabricate some tabs/lugs that trap the magnet then weld them to the shaft?
twybrow
posted on 22/9/16 at 06:50 PM Reply With Quote
I use plastic metal (epoxy). I build up a small amount all around each magnet and then over the top. I lost a magnet, but only as a result of my prop coming loose many moons ago.
jacko
posted on 22/9/16 at 06:51 PM Reply With Quote
What about gorilla glue the advert says its the best on the market
40inches
posted on 22/9/16 at 06:55 PM Reply With Quote
Same here, 3 different props, no magnets lost. I always file a small flat on the prop, or better still the diff /prop mounting flange, for a better bonding surface.
obfripper
posted on 22/9/16 at 07:01 PM Reply With Quote
Wurth Dual Cartridge Gun.Replast Easy Fast 2K Plastic Adhesive Black 50ml Kit
It's not cheap but sticks amazingly well and doesn't deteriorate with amine blush like a lot of epoxy based adhesives do.
If you know someone who works in a bodyshop/garage they are likely to use this stuff and could probably sort something out for a few beer tokens.
Dave
owelly
posted on 22/9/16 at 07:49 PM Reply With Quote
I drilled a counterbore in my flange (OOER MISSUS) and Araldited the magnet in. It was a ery snug fit witout the glue!
http://www.ppcmag.co.uk
posted on 22/9/16 at 08:12 PM Reply With Quote
Cover each magnet with a small patch of epoxy / carbon to spread the load?
posted on 22/9/16 at 09:42 PM Reply With Quote
I drilled a hole in the yoke, 2mm bigger than the magnet and half the thickness of it deep. Filled the hole with jb weld pushed the bmagnet so it was bjust proud and that was it!
Irony
posted on 22/9/16 at 10:05 PM Reply With Quote
I drilled a tiny hole as well. Snug fit. Once I put the magnet in to test fit I couldn't get the bugger back out. Took me a age to sort it.
mcerd1
posted on 23/9/16 at 07:02 AM Reply With Quote
Or change your sensor to one that doesn't need magnets
http://www.etbinstruments.com/index.php?route=product/product&path=99_110&product_id=56
with regards to the one with the magnets that etb sell they say - "Not recommended for new installations - in stock for direct replacements only!"
[Edited on 23/9/2016 by mcerd1]
posted on 23/9/16 at 07:49 AM Reply With Quote
From memory on my Sierra based MK Indy I used a two part adhesive to stick the magnets on the rear of the prop (just before if entered the diff.) and they never came off. May have been Araldite or similar.
russbost
posted on 23/9/16 at 01:20 PM Reply With Quote
It is ESSENTIAL to have the surface spotlessly clean, don't clean off with petrol/paraffin as they leave an oily residue, clean till shiny, preferably file a small flat, then wipe down with meths or nail varnish remover, brake cleaner or similar. If it's clean araldite should work fine, tho' I find JB Weld to be a better product. Making a small counterbored hole for the magnet to fit into as suggested above is pretty much foolproof as it gives the epoxy a much larger area to stick too, also helps to keep the prop in balance!
jacko
posted on 23/9/16 at 03:19 PM Reply With Quote
Dave
We use this at work and it is good on plastic like car bumpers but i would not use it on metal its to brittle and dose not adera very good
jacko
LBMEFM
posted on 23/9/16 at 08:33 PM Reply With Quote
Mine have been in place for five years, Alraldite then wrapped in Gaffer tape. Speedo works well with magnets still in place.
[Edited on 23/9/16 by LBMEFM]
nelmo
posted on 24/9/16 at 07:57 PM Reply With Quote
Go to a model shop and ask for this glue - by far the strongest stuff I have ever used. I've managed to glue my nail down onto the skin of the finger underneath and took 2 days of scrubbing to get it off.
Build Blog
SJ
posted on 24/9/16 at 08:25 PM Reply With Quote
I used 2 part epoxy plus a cable tie. It's been on for 8+ years now.
