robbydee
posted on 31/12/04 at 03:27 PM |
piston information?
right just started rebuilding a 2.0 pinto takenthe head off and read the following from the crown of the pistons.. anybody please shed light as to
what it means, i have some slap! at tdc so any recomendations please...
AE 21426v1 +0.50
91.295c sp 0.025
dzp
please any help....
theconrodkid
posted on 31/12/04 at 03:38 PM |
its .25mm over bored,91.295 is the bore size,pistons dont normally wear,the rings wear the bore,see if you can feel a ridge in the bore about 10mm
from the top,if there is a ridge it could do with a rebore,probly cheaper to get another engine
who cares who wins
pass the pork pies
posted on 31/12/04 at 05:19 PM |
It is already+ 50 thou overbore ----overbore sizes are by traddition in inches. 0.050" = approx 1.25mm
You will always get some slopp at the top of the bore it depends just how bad it is and how worn the rings are.
Normally the minimum rebore size is +0.020" (approx 0.5mm) maximum is usually +0.060" but this isn't he same for all engines,
it might be a +0.75" is easily available and the block has enough meat to take it --- check out the cost with your engine shop.
[Edited on 31/12/04 by britishtrident]
robbydee
posted on 31/12/04 at 05:31 PM |
just been and checked but there is no scoring and no RIM around the top of the cylinders..by slop. they dont wobble on their own.
robbydee
posted on 31/12/04 at 05:33 PM |
50 thou' you say so what would the new cc be?
these calculations are too much for me!
![](/images//smilies/sad.gif)
gazza285
posted on 31/12/04 at 05:56 PM |
Come on British Trident, get out of the dark ages, Pinto's were a metric engine from new, the +0.50 is millimetres (near enough the 20thou
mark), pistons are available right up to 94mm for this engine.
