Author: Subject: Tiger Avon Project - £2500 - SOLD - SOLD -SOLD
Retroboltsuk
posted on 23/10/16 at 08:04 PM Reply With Quote
Im selling my Tiger Avon Project. I have listed as much as I can remember below there is probably some bits that I have missed but ill be going down my unit this week to double check everything.
I bought this as a rolling chassis, I have stripped it right down and blasted and painted or powder coated pretty much everything that bolts to the chassis.
A load of new parts and a fresh rebuilt pinto. Its probably 80-90% there to complete
If you have any questions please let me know, ill be adding some more pics over the week but ill upload what I have
Genuine reason for sale just been told i have to be out the unit I rent early next year due to planning permission being approved
Feel free to call (up till 8.00pm) or text (anytime) 07968809437
Email - retrobolts@gmail.com
Location – Bedfordshire
CHASSIS, SUSPENSION & STEERING
Chassis – blasted & painted
Front Wishbones (powder coated)
New Front Lower ball joints
Front wing stays (Powder Coated)
Rear wishbone (Powder Coated)
Rear Hubs (Powder Coated)
Front Hubs (Powder Coated)
New Front Bearing (I think – im sure they are in there somewhere)
Suspension (GAZ)
Steering rack
Steering rack to chassis Brackets (Powder Coated)
Front M16 calliper & Solid Discs
Rear Drums – New shoes - New Cylinders - New Fitting Kit
Steering Column & Steering wheel
14” 5 Spoke Alloy Wheels & tyres
New polybush set
New alloy panel set
ENGINE & TRANSMISION
Rebuilt 2.0 Pinto – No clutch or Alternator
Strip down and painted
New bearings
New gaskets
New Felpro head gasket
New Bolt Kit (Stainless)
New Head Bolts
fast road cam
Twin DCOE Inlet Manifold
Electronic Ignition
Modified Sump (Powder Coated)
Stainless Pinto Exhaust Manifold and System (Bike back box)
4 x dcoe weber carbs – (stripped) – should be able to make a good pair out of the 4
Type 9 5 speed gear box & gear lever extension + Steel bell housing
Avon Pinto prop shaft
Std sierra diff
Rear drive shafts
BODY WORK – Go Faster Yellow
Front Cycle wings
Nose
Bonnet
Tub – has a few cracks and fractures that would need sorting but usable
MICS
Petal tank + Filler cap
GRP Bucket Seats
Headlamps (2 sets 1 black 1 chrome)
Front indicators
Wiring loom (I assume it is complete)
Sierra pedal box in bits (would recommend this upgraded anyway
Radiator (would need a rebuild I think)
Roll Bar
Im also pretty sure i have a fuel pump and fuel filter and regulator
this was how i got it
Stripped
Chassis Blasted & Primed
Halfway through paint - NOW FULLY PAINTED
THANKS
[Edited on 25/10/16 by Retroboltsuk]
