russbost
posted on 27/10/16 at 05:47 PM |
FF bodywork ideal for single seater project - Cheap!
I have 3 sets or part sets of Historic Formula Ford bodywork for sale, would be ideal for anyone working on a single seater or possibly a trike
project, could save many hours of fabrication, or at a minimum be a good starting point. Looking for around £100 per set, certainly open to offers to
clear the lot, would need to be collected from Benfleet, Essex, 20 mins from M25 Dartford crossing. As long as time is not important could probably
get it up to Leeds in a few weeks if that helps, but would need paying for first!
The first set is, I believe from Hawke DL19, see pics below:-
[img]
[/img]
[img]
[/img]
[img]
[/img]
General condition is sound, needs rubbing down & painting obviously, there is a small crack in the nose section, fairly simple to fibreglass a
repair in from behind & fill to finish
Second one I posted here last week trying to identify & the Locost masif failed miserably! So it's unknown bodywork in one piece moulding
from a FF probably around mid 70's at a guess
[img]
[/img]
[img]
[/img]
[img]
[/img]
Again in sound condition, just needs preparation & paint
The 3rd "set" isn't actually a set, the nose roughly matches the dimensions of the centre section (centre is Hawke DL19, same as
first set), but the rear would need modifying to fit the back of the centre section, the back end needs a good sanding off to remove loads of crap
paint prior to prep & paint. Centre section has a small crack at the front, again easily repaired, see pics below
[img]
[/img]
[img]
[/img]
[img]
FF rear blue
[/img]
As usual U2U if interested or email me on russbost at googlemail dot com or ring 07914 258651
[Edited on 27/10/16 by russbost]
russbost
posted on 29/10/16 at 09:47 AM |
Bump!
russbost
Bump!
