Author: Subject: Should I be worried?
david_hornet27
posted on 6/11/16 at 01:02 PM Reply With Quote
Hi
My Sierra MK1 indicator stalk packed up so I replaced it with a MK2 as that is all I could get my hands on. I plugged it in expecting for it not to work after searching on here, but it works. Should I expect blown fuses etc in the future? BTW it is the one without the horn button, and the MK2 had one extra pin.
'If everything seems under control you're just not going fast enough' - Mario Andretti
snapper
posted on 6/11/16 at 03:22 PM Reply With Quote
The later Sierra stalks were designed for low power so you need a few relay's or you'll burn the contacts out
I eat to survive
I drink to forget
david_hornet27
posted on 6/11/16 at 08:22 PM Reply With Quote
OK thanks Snapper. I will wire some in.
