Author: Subject: 12mm R9 Fuel Hose
Jamesc
posted on 31/1/17 at 11:06 AM Reply With Quote
12mm R9 Fuel Hose
Hello,
I was wondering if anyone has a small amount of 12mm R9 fuel hose laying around? Will only need around 300mm..
I can't seem to find anywhere that sells 12mm, only up to 10mm. If not, I'll have to use R6.
James
Dingz
posted on 31/1/17 at 09:01 PM Reply With Quote
Don't use R6 with petrol it will eat it!
went on and on.
Jamesc
posted on 31/1/17 at 09:08 PM Reply With Quote
Yeah, I've experienced that before! Didn't take very long either.
I'm a bit miffed as to why I can't find R9 in 12mm though... The fuel pump has a 12mm inlet, so can't be that unheard of.
Rosco86
posted on 31/1/17 at 09:49 PM Reply With Quote
Have you looked for 1/2"? As thats 12.7mm
My Build Thread
Rosco86
posted on 31/1/17 at 09:51 PM Reply With Quote
Here you go https://www.ebay.co.uk/itm/272452052562
My Build Thread
Jamesc
posted on 31/1/17 at 10:12 PM Reply With Quote
Cheers mate, didn't think of that, but not sure if that will be a little sloppy as all my connections are 12mm.
Is R9 minimum standard?
Dingz
posted on 31/1/17 at 11:20 PM Reply With Quote
The hose needs a fluorocarbon (Viton) liner to resist the modern additives. PTFE hose would be fine but its not very flexible.
went on and on.
