super-ron
posted on 25/5/17 at 07:08 AM |
Building Haynes Roadster Wishbones - seamless? oval?
I'm going to be building a new set of front wishbones to Haynes Roadster book spec. I've sourced everything apart from the 25mm seamless
tube for the main arms which I'm having some trouble with. is it essential to be seamless?
ideally I'd like to use oval tube because personally I think it looks loads better, but all the threads I've read on it not being suitable
for roadster chassis with the shock placement as it is however, I can't find any new threads on the matter, only archive ones. is there
suitable oval 'tube' suitable for wishbones now?
The on the top arms I'm considering using rose joints instead of bushes to give me adjustable castor.
any suggestions greatly received
Nathsx
posted on 25/5/17 at 07:29 AM |
Aerofoil would be interesting
http://proformancemetals.co.uk/wp-content/uploads/2016/04/Aero-Section-2016-complete.pdf
Oval here :
http://proformancemetals.co.uk/wp-content/uploads/2016/04/Oval-Section-2016-complete.pdf
Not sure on the required material attributes though
voucht
posted on 25/5/17 at 07:37 AM |
No, you don't need seamless tubes for the wishbones, but at least ERW tubes.
You should check and perhaps register to the Haynes Roadster forum. Some builders used rose
joints on their wishbones, and you might find useful informations there.
Hope that will help
555
super-ron
posted on 25/5/17 at 07:52 AM |
quote: Originally posted by voucht
Hope that will help
I keep trying to register to that forum bit it won't let me, tried emailing administration but no response
ianhurley20
posted on 25/5/17 at 05:51 PM |
Keep trying Super-ron it will work eventually and it's worth it for the expertise there is there. It took me ages to get on the forum 3 years
ago and has not improved I'm afraid but there is a lot of helpful types there
Ian
super-ron
posted on 25/5/17 at 08:49 PM |
Ian
I'll keep trying then. I've been trying for weeks. their threads do always come up in Google on searches i do but when you go to view
links in the thread it says you must sign in to see this.
super-ron
posted on 1/6/17 at 07:36 AM |
I've still not had any luck logging on to the haynes forum!
has anyone got any opinions on the matter at the top?
Myke 2463
posted on 1/6/17 at 09:38 AM |
Haynes site.
You have pm.
Be Lucky Mike.
