Author: Subject: Alternatives to Sierra column switches
Rosco
posted on 4/6/17 at 02:57 PM Reply With Quote
I have the old Sierra steering column stalks from a donor car but they're a bit old and temperamental. I wondered if there are any direct replacements available or whether the best option is new ones from ebay.
Ford Transit switches look similar - do these fit?
A few years ago someone sold replacements with nice turned aluminium ends - are these still available?
posted on 4/6/17 at 04:32 PM Reply With Quote
I think it really depend on whether or not the multi plug connectors would fit or would they need to be reworded ? Most Ford switches might fit but later cars probably need relays in the circuits as they may not be able to cope with things like headlamp or wiper loads?
big-vee-twin
posted on 4/6/17 at 10:21 PM Reply With Quote
The aluminium stalks just screw into the Sierra switch bodies after cutting original arms off. Look on the Zero site they sell them, the switches also.
http://www.triangleltd.com
Badger_McLetcher
posted on 7/6/17 at 10:04 PM Reply With Quote
Not sure if these are any good for you, but they just popped up on CBS. May require some re-wiring.
https://www.carbuildersolutions.com/uk/multi-stalk-assembly
If disfunction is a function, then I must be some kind of genius.
