Author: Subject: Water temp sensor connectors
ianm67
posted on 7/7/17 at 07:21 AM Reply With Quote
Good morning all,
I am hoping that the Locost Collective may be able to point me in the direction of where I can buy a couple of connectors for this Ford WTS online....... I've failed dismally so far.......
Many thanks in advance!
Always biting off more than I can chew.....
pekwah1
posted on 7/7/17 at 08:04 AM Reply With Quote
Doesn't help you, but i've just picked up my new one of these this morning, strange!
There was a website years ago that someone gave me which sold OEM type connectors, i'll have another look for it again as someone else was after it but didn't have much luck the first time, maybe someone else on here remembers.
tims31
posted on 7/7/17 at 08:51 AM Reply With Quote
I looked for these but had no luck. In the end I ended up getting the plugs from a scrappy cut from the loom and splicing them in.
Build: http://www.martinsfurybuild.co.uk/
pekwah1
posted on 7/7/17 at 10:17 AM Reply With Quote
a scrappy would be the obvious place, should be hundreds to choose from!
peter030371
posted on 7/7/17 at 10:40 AM Reply With Quote
Is it any of these https://www.simtekuk.co.uk/index.php/automotive_connectors/?k=:8::
davidimurray
posted on 7/7/17 at 11:05 AM Reply With Quote
See my thread here
https://www.locostbuilders.co.uk/viewthread.php?tid=194663
Have a look at TE connectivity. If you can work out the connector you can order free samples. I got cam, crank and oil pressure connectors all new for free from them for the Duratec!
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
r1_pete
posted on 7/7/17 at 03:20 PM Reply With Quote
They look similar hopefully the same as denso injectors, if they are Ive a few, will check later.
ianm67
posted on 8/7/17 at 05:43 PM Reply With Quote
Awesome !! Just the job, many thanks !!
