Author: Subject: pinto engine weight
smart51
posted on 10/1/05 at 10:38 AM Reply With Quote
pinto engine weight
people keep telling me that pinto / CVH engines from sierras are very heavy. how much do they weigh?
Surrey Dave
posted on 10/1/05 at 10:49 AM Reply With Quote
They are heavy but I cant see how they could weigh much different to a Vauxhall XE or a Ford Zetec..........
They're ALL heavy!!!!.
Rover 'K' series should be light as its all ally, and probably the old crossflow is a smaller lighter engine.
But I wouldnt like to carry any of 'em!!........
ned
posted on 10/1/05 at 10:57 AM Reply With Quote
fluke motorsport i think it is has a section on their website with weights of various engine and transmission combo's on it's site.
basically 2ltr iron blocks are heavy (pinto, zetec, xe), rover v8 is not much more as it's ally but it is large so is heaviest that i know of amongst common choices. zetec se, 4age, duratec, k series are light alloy block engines with small iron block xflow inbetween.
so something like (roughly in order of weight, heaviest first with ancillaries):
ford essex v6
ford cologne v6
rover v8/duratec v6/ford sierra dohc
pinto/zetec/xe
cvh
xflow
duratec/zetec se/k-series/4age
Ned.
beware, I've got yellow skin
bob
posted on 10/1/05 at 11:08 AM Reply With Quote
Rover V8 weighs about the same as a pinto,wierd i know
ned
posted on 10/1/05 at 11:10 AM Reply With Quote
bob,
i think the short engine is the same, but by the time you add ancillaries, two exhaust headers etc etc it then weighs more. didn't chrisg weigh some engines at a scrappy a while back?
Ned.
locoboy
posted on 10/1/05 at 11:11 AM Reply With Quote
Bob,
Its got 2 twice as many big fresh air spaces surely that makes it lighter
Locoboy
keith2lp
posted on 10/1/05 at 11:53 AM Reply With Quote
Engine Weight
Hi
According to Which Kit these are the weights of the most common 4 pots fully dressed.
Crossflow 110 kgs
Pinto 135 kgs
Zetec 115 kgs
Zetec SE ( all alloy found in the later focus & fiesta & only 1.6 & 1.25) 81 kgs
Duratec 97 kgs
Vauxhall XE 120 kgs
Rover K series 100 kgs
Toyata 4-AGE 100 kgs
Another point to note is that the K Series is the only engine that can be installed in a 7 type car with out any modifiaction to the standard plenum /injection system.
[Edited on 10/1/05 by keith2lp]
ned
posted on 10/1/05 at 12:07 PM Reply With Quote
so rearranged in weight order not far from my rough guide at all!
Ned.
bob
posted on 10/1/05 at 12:21 PM Reply With Quote
RV8 comes in at 160kg according to this thread.
http://www.locostbuilders.co.uk/viewthread.php?tid=12640
posted on 10/1/05 at 12:42 PM Reply With Quote
The Rover K is a fair bit lighter than 100kg dressed ---The engines is light not just because of the alloy block and head but because every single component on the engine is designed for minium weight, for example the inlet manifold and throttlebody weighs about 1/3 that of an XFlo GT carb and manifold, the clutch and flywheel are about half the weight of the equivalent xflo 1600 unit, and as the coolant capacity is a fair bit less that saves a few pounds.
posted on 10/1/05 at 12:45 PM Reply With Quote
With the RV is it easy to forget that it also requires two exhaust systems, more fuel bigger battery and more that all add to the weight.
Volvorsport
posted on 10/1/05 at 12:58 PM Reply With Quote
also B230E is about 120 kgs , more with turbo - but its 180 hp.
www.dbsmotorsport.co.uk
getting dirty under a bus
locoboy
posted on 10/1/05 at 01:19 PM Reply With Quote
Just a thought - did any of you see the Worlds Strongest Man competition over the Christmas break?
They were doing the 'Farmers Walk' basically a large weight in each hand and doing a 30m dash!
The weight in EACH hand was 160kg - or a RV8 fully dressed in each hand - now that makes it slightly MORE impressive!
Locoboy
stressy
posted on 10/1/05 at 09:47 PM Reply With Quote
1600k series with flywheel, injection gubbins,alternator, coilpack, leads and oil filter is a touch over the 82kg mark. Its less than 90 with the clutch and 4-1 exhaust on.
Just for info,
WHO DARES SPINS
Rorty
posted on 11/1/05 at 02:17 AM Reply With Quote
RV8 is 144.5 kg. So obviously NOT lighter than the Pinto as I stated in another thread.
Cheers, Rorty.
