Author: Subject: Duratec alternator - Brise mounting Denso
jrod
posted on 22/8/17 at 03:39 PM Reply With Quote
I'm replacing the old Lucas style alternator with a smaller Denso type.
I bought one of the Brise mounting kits (from Demon tweeks as they actually sell it cheaper)
http://www.brise.co.uk/Bracket-MTK003.html
Stock photo:
My Alternator:
Note - I've actually rebuilt it to rotate the internal since this photo. This cant have changed the fitment though as the mountings are all on the 1 side of the casting.
Now for fitting it, when the bottom bolt is fitted and nipped up the gap at the top seems fairly large, I can bolt it up but it doesnt seem 'right'
I cant see that I should be using any spacers so I'm slightly confused as to the correct mounting.
I can't really test it as my pulley hasnt arrived but just wondered if anyone had used one prior.
Any Thoughts?
mackei23b
posted on 22/8/17 at 05:36 PM Reply With Quote
I don't want to be the bearer of bad news but I think there are two castings available which mirror each other, have a look here and see what you think: https://www.google.co.uk/search?q=denso+lightweight+alternator&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjOqtSMsOvVAhWHCcAKHRbQAKUQ_AUICygC &biw=1920&bih=925
[Edited on 22/8/17 by mackei23b]
jrod
posted on 22/8/17 at 06:40 PM Reply With Quote
From the look of all the images, the large 10mm mounting is always towards the front pulley side.
I'd be quite happy if I had the wrong alternator as It's a very easy fix.
big-vee-twin
posted on 22/8/17 at 07:21 PM Reply With Quote
My alternators on the other side to aviod heat from the manifold and provide clearence for the steering column. Mounted on some home made brackets.
[img] ND Alternator
ND Alternator
[/img]
[Edited on 22/8/17 by big-vee-twin]
http://www.triangleltd.com
starterman
posted on 22/8/17 at 08:08 PM Reply With Quote
[img] ND Alternator
ND Alternator
[/img]
Just being nosey but how much did you pay for your alternator?
big-vee-twin
posted on 22/8/17 at 09:41 PM Reply With Quote
It was used so paid about £70 taken off a Westfield.
But you can source them on ebay from a Diahatsu Charade.
starterman
posted on 23/8/17 at 06:21 AM Reply With Quote
Even second hand it's too expensive
neilp1
posted on 23/8/17 at 11:47 AM Reply With Quote
I made my brackets as I'm too tight to buy nice shiney ones
dave r
posted on 23/8/17 at 03:38 PM Reply With Quote
made my own 2.... low down inlet side
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
jrod
posted on 23/8/17 at 05:16 PM Reply With Quote
Brise advised top bracket is the wrong version and they are replacing for me, hopefully all sorted soon.
jrod
posted on 24/8/17 at 04:54 PM Reply With Quote
Bracket Arrived, Problem Solved.
