barraw
posted on 2/9/17 at 11:12 AM |
OMEX 600 initial set up
Hello
can anyone do an initial set up on a OMEX600?
I think my flywheel may not be lined up where the ECU thinks it is
In Retford area and happy to pay for help from anyone who knows their stuff
Even a remote session through teamviewer etc onto my laptop would help
posted on 2/9/17 at 11:22 AM |
What engine is it? Normally the flywheel only bolts on in one position...
barraw
posted on 2/9/17 at 11:30 AM |
ST170 with static timing
See my recent plea for help :- )
http://www.locostbuilders.co.uk/forum/9/viewthread.php?tid=210102
theduck
posted on 2/9/17 at 01:03 PM |
I'm not familiar with the omex software, has it got a trigger offset setting?
barraw
posted on 2/9/17 at 01:31 PM |
not by that name. it has a mX tooth setting on the crank sensor set up, which is set to 34. when I crank the engine it shows "stat
sync'd" (not sure what that means but it's good apparantly", but when I change it to any other tooth the 'stat
syn'd" = no
jeffw
posted on 2/9/17 at 05:26 PM |
I suggest you ring Omex on Monday, they will have a standard map for an ST170 and will talk you through it.
barraw
posted on 2/9/17 at 11:06 PM |
Omex have been helpful and sent me a ST170 map, but still not running
jeffw
posted on 3/9/17 at 06:53 AM |
Speak to them again and ask them who they recommend to map the car local to you and the take it there. They can get it running and map it for you.
barraw
posted on 3/9/17 at 10:15 PM |
Will do - thanks
