Author: Subject: 1 inch crack = written off Corvette
r1_pete
posted on 13/9/17 at 04:52 PM Reply With Quote
Don't know whether This is unbelievable or fascinating, but its a real pisser for the owner.
[Edited on 13/9/17 by r1_pete]
ian locostzx9rc2
posted on 13/9/17 at 05:21 PM Reply With Quote
Not sure where that is or what it's made off but I'm sure it could be repaired but insurance companies right off car very easily these days .
scudderfish
posted on 13/9/17 at 06:13 PM Reply With Quote
When I had a Lotus Elise, I went off a roundabout and bounce over a kerb. Near the top rear suspension mount I cracked the glue in a joint in the chassis. The chassis was replaced and the bill came to only £14k as Lotus charged about £28 per hour to the insurance company.
Slimy38
posted on 13/9/17 at 06:14 PM Reply With Quote
Go into the forum and have a look at the repair bill... it's shocking!!
M8x1.25x30 bolts, four of, $18.72...
More than 2K for a new exhaust...
2.5K to take out and put back the drivetrain...
$186 for 'panel bond', erm does that mean 'a tube of glue'??
The bill doesn't even include the actual part of the chassis that needs to be replaced!!
theconrodkid
posted on 14/9/17 at 06:52 AM Reply With Quote
there is a fella on youtube that buys writeoffs in the us ( copart), he has shown some tesla ,s that have been written off just for a scrape and some paintwork, has to be a scam ?
who cares who wins
pass the pork pies
Bluemoon
posted on 14/9/17 at 07:21 AM Reply With Quote
Probably.. I do see the issue though if it was a steel chassis fine it would be an easy fix, but a if a highly stressed aluminium part is cracked as claimed not so sure? It seems to be the junction between chassis elements that's cracked and reading around that part may be boned not just welded to the rest of the chassis making repair a PITA. Still repair might be possible?
Still photos don't convince me it's actually a crack, the crack is looks dark in the photos (i.e. is this actually a crease from production that is painted over?)...
[Edited on 14/9/17 by Bluemoon]
Ugg10
posted on 14/9/17 at 10:41 AM Reply With Quote
At £28 per hour they can service my car anytime, not sure how they can make any money on that.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
jollygreengiant
posted on 14/9/17 at 11:05 AM Reply With Quote
IF I understand the construction of a Corvette body shell correctly, they have a steel chassis that has the body shell formed around it. So the glass fibre laminate is formed (as I understand it) and directly bonded to it. Hence the cost of repair and writing off.
Edit bit. If you want some idea of the complexity of fixing cracks in Corvette body, just watch channel 4's Car SOS season 3 episode 9 - Little black Corvette.
[Edited on 14/9/17 by jollygreengiant]
davidimurray
posted on 14/9/17 at 12:28 PM Reply With Quote
It's difficult to see in the pictures, but it looks like more than a 'bump'. You can see where the material has been scraped off as if it has been grounded. I wouldn't think that was a crack, it actually look like the material has been ground away. If you look at the 'plugs' around the area they seem to have 4-5 rings, the main one in the damaged area has 2-3 so is that a suggestion that the whole area is half as thick as it should be!
If it is a bonded chassis then welding would be a challenge - how do you control heat flow so as not to damage components or the bonding in. I'm sure it could be done - but it would be at the liability of the repairer if something happened.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
morcus
posted on 14/9/17 at 06:33 PM Reply With Quote
I saw this on Jalopnik this morning and there article did seem to suggest the big issue was warrantee and the part not being available through official means. TBH if it was a fairly new car you are better off if its written off as the record of the repair showing up will make your car much harder to pass on at the end of your ownership.
davew823
posted on 15/9/17 at 11:16 AM Reply With Quote
vette
You are probably on the right track with warranty, plus you add in the corporate lawyers in the USA, and things get real stickie. The original aluminum Z06 frame was design to have both front and rear frame weld-on clips replaced, note a triangle in the frame side rail as pick up point for sectioning. But only at selected dealers with the correct equipment and special GM training for the techs. My guess is that a few dealers screw up the repair jobs, an hence the lawyers now taking the " it's totaled" way out. Davew823
posted on 15/9/17 at 11:36 AM Reply With Quote
That's exactly what I thought, it looks very much like a fair bit of material has been ground away and the material has been thinned. However I'd have expected that would have required a fairly sustained 'grounding' on something rather than a rock etc. bouncing down the bottom of the car.
