Jon Ison
posted on 4/10/17 at 03:12 PM |
Supercharged hayabusa engine.
And everything to make it run.
Can be seen at Cadwell on the 22nd available immediately after.
Procharger running a very modest 10psi for reliability, 224@ wheels tourque curve is not a curve just a flat line. Running sweet, great oil pressure
& well maintained, all big cc mods to run a charger.
Will include brain, power commander, power commander hub, fuel pump, fuel regulator which increases fuel pressure as boost rises, absolute everything
to make it run, modded sump & accusump which I've run reliably for over 10 years on busa's.
Has took overhaul FTD on last 2 sprints entered, £4995.
Will be breaking car once I robbed what few bits I want off it or if your interested in whole car as is maybe we can chat?
https://youtu.be/FoCuFszFS7E
https://m.youtube.com/watch?v=TdRpY1z9nCo
https://m.youtube.com/watch?v=YwjuiJr-KpY
adithorp
posted on 5/10/17 at 08:45 AM |
That'll be the end of an era. Have you got new plans?
http://jpsc.org.uk/forum/
PumaWestie
posted on 5/10/17 at 09:38 AM |
Out of interest, what cc is it and is it standard internals?
Jon Ison
posted on 5/10/17 at 04:09 PM |
Gen 1 std bore, updated clutch, updated output shaft, base plate to lower compression new rod bolts & bearings at same time, internals are good
for 300bhp
