Author: Subject: 4A-GE 20v cam belt
martinnitram
posted on 10/10/17 at 09:10 AM Reply With Quote
4A-GE 20v cam belt
Trying to track down a cam belt for my 20v silvertop without much luck
Where is everyone getting their cam belts from, without sending off to America.
The belt on mine is approx. 17mm wide and has 111 teeth
Tried jap car specialists but they all want a reg number
voucht
Contributor
Posts 229
Registered 22/5/11
Location 1
Member Is Offline
Photo Archive Go!
Building: Haynes roadster on the road since november 2014 bu
posted on 10/10/17 at 10:28 AM Reply With Quote
Have you tried Quinton Hazell ?
555
Angel Acevedo
posted on 10/10/17 at 06:26 PM Reply With Quote
Look for Cogged Belt, 5/8 X 115 teeth...
You should find several options.
5/8" is about 16 mm so should be close enough.
Angel Acevedo
posted on 10/10/17 at 06:38 PM Reply With Quote
Further digging shows this should be what you are loooking for...
No connection to me whatsoever...
https://www.gprindustrial.com/en/2132-bx-v-belts/2332-BX115-cogged-belt.html
obfripper
posted on 10/10/17 at 06:55 PM Reply With Quote
Gates 5124 from local factors, eurocarparts or ebay should do the trick or 13568-19035 from your toyota dealer if they're friendly enough.
Dave
martinnitram
posted on 10/10/17 at 09:38 PM Reply With Quote
Dave
That's the one, Gates 5124, 111 teeth
martinnitram
posted on 11/10/17 at 08:04 AM Reply With Quote
Don't suppose you know the number for the tensioner roller do you ? ;-)
obfripper
posted on 11/10/17 at 08:24 AM Reply With Quote
The tensioner is 13505-16021, it's the same as 16v 4age models.
Dave
Worzey
posted on 11/10/17 at 07:10 PM Reply With Quote
Have you tried FenSport? I'm sure that's where I got mine from when my engine was rebuilt.
https://www.fensport.co.uk/
Caterham R400
martinnitram
posted on 11/10/17 at 09:32 PM Reply With Quote
Dave
Ill have a look for one.
Thankyou
martinnitram
posted on 11/10/17 at 09:35 PM Reply With Quote
No never heard of them, and they didn't come up when ive been searching, see they are involved in 4A-GE parts, so a useful link to have.
Thanks for that.
