Author: Subject: Honda Civic VTEC engine - in a Locost?
Mike Wood
posted on 21/10/17 at 04:52 PM Reply With Quote
Hi
Anyone put a Honda Civic VTEC engine into a Locost? Not a rwd Honda S2000 engine and gearbox.
If so, how as I understand they run in the opposite direction to normal car engines so not sure what rwd gearbox and differential would work.
Mike
rdodger
posted on 21/10/17 at 05:19 PM Reply With Quote
The Civic 2L Type R engine runs in the correct direction.
posted on 21/10/17 at 05:27 PM Reply With Quote
Kurt built the Midlana with one
CosKev3
posted on 21/10/17 at 06:48 PM Reply With Quote
Was a Westfield built/part built with one in,iirc bell housing came from Australia for it.
Think that was the hardest part to find.
daniel mason
posted on 21/10/17 at 09:01 PM Reply With Quote
The Bunn/hodder Westfield runs a k20 with forced induction. It's rapid!
CosKev3
posted on 21/10/17 at 09:12 PM Reply With Quote
http://forum.wscc.co.uk/forum/topic/110326-westfield-16-race-car-full-rebuild-with-honda-k20/
That's the one I had seen,shame the rip off Photo bucket assholes have blocked pics
inkafone
posted on 22/10/17 at 01:08 PM Reply With Quote
FIX
obfripper
posted on 22/10/17 at 06:07 PM Reply With Quote
Doug Bennett has a k23 (tall block k20) with supercharger in his sports libre Striker, i dont know what gearbox he's running but it sounds sequential, straight cut (and expensive).
If you're looking for a cheaper option, an rx8 box and an adaptor plate looks like a good solution.
honda VTEC K20 To rx8 gearbox conversion plate CNC LASER CUT RWD Ford Rally
The rx8 ratios are a bit short on 1st, but the rest are ok, a long diff ratio may make 1st useable but would leave 5/6th as cruising gears.
The other option is to butcher the bellhousing portion from a civic fwd gearbox and make an adaptor plate to mate with a type 9, either bolted on or welded.
This could be cheaper if you've the engineering gear, if your paying someone else it's probably uneconomical.
Dave
