New Topic New Reply
Author: Subject: uploading photo.s
andybod
posted on 14/1/05 at 09:22 AM Reply With Quote
uploading photo.s
sorry to sound thick but how do you upload photo,s every time i try it comes up cannot find server can somebody help and give me some simple instruction,s thanks
tom_loughlin
posted on 14/1/05 at 11:17 AM Reply With Quote
im having the same trouble, it thinks about it, hen either tells me 'the file type is not supported - email chrisW if you think it should be', or 'cannot find server...'
Tom
mangogrooveworkshop
posted on 14/1/05 at 11:40 AM Reply With Quote
R u using Moz Fire Fox per chance?
andybod
posted on 14/1/05 at 11:42 AM Reply With Quote
whats that then
mattpilmoor
posted on 14/1/05 at 12:45 PM Reply With Quote
I had this problem. It seemed to work after i'd reduced the file size. It's got to be waorth a try!
Matt
Measure twice - Cut once - Still f*!K it up!
tom_loughlin
posted on 14/1/05 at 02:22 PM Reply With Quote
whats the easiest way to reduce the file size of a pic?
cheers,
Tom
mattpilmoor
posted on 14/1/05 at 02:37 PM Reply With Quote
I used Adobe photoshop. My pictures were taken at 2Mpixle, I loaded them up in photoshop and saved a copy in .jpg format. When you do this photoshop prompts you to enter the quality of the copy. I picked low/medium and this reduced the file size considerably. There's probably an easier way though!
Hope this helps
Matt
lewis635
posted on 14/1/05 at 02:53 PM Reply With Quote
I am also having the same problem.
andybod
posted on 14/1/05 at 03:03 PM Reply With Quote
good to see i,m not the only one who doesn,t have a clue at what there doing managed to upload a photo of my dog and a piece of the chassis anything else just won,t go
ned
posted on 14/1/05 at 03:19 PM Reply With Quote
chris has put a full size (kb's) limit on files for uploading, can't remember what it is though...
Ned.
edit: just asked chris and it's 250k.
[Edited on 14/1/05 by ned]
beware, I've got yellow skin
andybod
posted on 14/1/05 at 03:51 PM Reply With Quote
how do i go about reducing size of photo.s stressed now these computer thing,s don,t like me
posted on 14/1/05 at 04:00 PM Reply With Quote
get your digital picture in your photoediting software and reduce the image size from 1600x1200 (2.1Mp) to say 600x400. Screen resolution is predetermined at 72dpi which should be the same as the oputput file resolution. If your software has it - you need to export as web picture. This gives you the option to choose your quality of image and it will optimise. This will reduce filesize and give you the best picture quality you require. Then save as a copy of your original file.
Hope this helps
posted on 14/1/05 at 04:07 PM Reply With Quote
If anyone is looking for a cheap (i.e. free) advanced graphics editor then I can recommend The GIMP, as found on Linux systems. It's now available for just about every Windows platform
HERE
Takes a bit of learning, but it's very powerful and the price is right...
andybod
posted on 14/1/05 at 04:39 PM Reply With Quote
i think i,ve finally managed it just need to spend hours resizing pictures and start uploading them thanks for all help and suggestion,s
Dusty
posted on 14/1/05 at 05:27 PM Reply With Quote
A very easy to use image resize program is available here as a shareware free trial.
flak monkey
posted on 14/1/05 at 06:38 PM Reply With Quote
Of course if you have microsoft office then you have photo editor, its not installed as a standard option though. That is a simple photo editor, and will let you adjust jpeg compression when saving as well.
Sera
http://www.motosera.com
lukefab
posted on 30/1/05 at 07:10 PM Reply With Quote
Hi
After following all the advice I still find I can't send my photos. Is it possible to email them in the form of an attachment?
New Topic New Reply
