Author: Subject: Which white pen to mark bolts with?
bi22le
posted on 30/4/18 at 09:35 PM Reply With Quote
In the past I have marked torqued bolts with a Sharpie so, at a glance, I can check over the cars crucial bolts and know everything is good.
Sharpies are not great for this. The lines are hard to see and dirt easily covers them. Also after a few refits you end up with multiple lines, leading to confusion.
So what would you recommend. I have tried tippex in the paste but it is often too runny and not a solid white colour when dry.
Thoughts?
Please read my ring story:
obfripper
posted on 30/4/18 at 09:45 PM Reply With Quote
A paint marker pen is what you need, you can buy pretty much any colour you want, white and yellow stand out clearest.
Dave
40inches
I use a fine tippex pen, still there after 5 years
Ugg10
posted on 30/4/18 at 09:47 PM Reply With Quote
I use nail polish/varnish colour co-ordinated to the colour of the car.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
PAUL FISHER
posted on 30/4/18 at 10:43 PM Reply With Quote
White tyre letter marker pen has worked well for me.
mcerd1
posted on 30/4/18 at 11:18 PM Reply With Quote
Search for inspection lacquers on Amazon or eBay
It's the professional stuff used one aerospace stuff, but it's not expensive
907
posted on 30/4/18 at 11:31 PM Reply With Quote
Two Paul's think alike.
Paul G
[Edited on 30/4/18 by 907]
loggyboy
posted on 1/5/18 at 06:00 AM Reply With Quote
The magic search word is Torque seal
https://www.ebay.co.uk/itm/Dykem-Cross-Check-Torque-Seal-F900-Equivalent/122078798310
Mistral Motorsport
posted on 1/5/18 at 08:34 AM Reply With Quote
Same techniques I've used myself - a dab of SWMBOs nail varnish on the bolt/nut and alinged on the housing surface. Cheap as chips and lasts for a long time. Marking both sections also gives you a visual check to see if anything has moved.
tims31
posted on 1/5/18 at 05:23 PM Reply With Quote
Halfrauds do a yellow marker paint which has a brush and sharp point for about £4.00 which is what I used for my build
Build: http://www.martinsfurybuild.co.uk/
bi22le
posted on 1/5/18 at 07:18 PM Reply With Quote
Thanks for the replies all. Some good suggestions.
Case closed!!!
snapper
posted on 2/5/18 at 03:43 AM Reply With Quote
My huge hairy cousin who is built like a brick outhouse after working on heavy lorry’s for 30 years has an alarming array of nail varnish available from its own draw in his shed sized Snapon roll cab. He was only last week discussing with his fellow hairy lorry techs the merits of different colours.
I have a small but perfectly formed set of very nice metallics purloined from my daughters collection.
Now if they did sequinned overalls and high heals with steel toe caps!
I eat to survive
I drink to forget
posted on 3/5/18 at 09:00 AM Reply With Quote
snapper....
You've mentioned sequins - I have a 10 year old daughter who loves them and I'm often faced with hoovering the damned things up before treading them all over the house
jester
Contributor
Posts 154
Registered 21/5/17
Member Is Offline
Photo Archive Go!
Building: brought Jester.building a Jester own a Striker
posted on 3/5/18 at 09:49 PM Reply With Quote
OMG Have you seen the bottom front of that tube might need a chemical suit when using that stuff
bi22le
posted on 3/5/18 at 10:15 PM Reply With Quote
The image is to poo to read it. I assume it does not make a very good drink or eye wash!!?
ste
posted on 4/5/18 at 05:29 AM Reply With Quote
I work in the aerospace industry and we use edding 751 paint pens to add witness lines to torqued nuts and bolts. If you want to stick to military spec, then use red to mark nuts and bolts and white to mark pipes and hoses
ste
posted on 4/5/18 at 05:30 AM Reply With Quote
https://www.ebay.co.uk/itm/Edding-751-Paint-Marker-Pens-Fine-Bullet-Tip-All-Colours-For-Hobby-Crafts-/380827107455
