Author: Subject: Deposit Taken - CBR1000RR engine and parts
Flick
posted on 6/6/18 at 12:59 PM Reply With Quote
Hi, thinking of trying something different for a while so selling my spare blade engine and parts.
2009 fully rebuilt, new seals, rings gaskets etc. Not run since rebuild. Ab billet sump and baffle. Hrc clutch diaphragm. Water pump delete, external water pump, prop adapter, loom inc all deletes, resistors etc fitted and wires to connect ign, neutral, fi etc labelled, rec reg, Pcv, hiss, oil cooler take off, modded airbox with high flow filter and ab velocity stacks. Reed covers deleted. Engine number is present. basically a near full pack eng install, little work and parts would be needed.
Spare crank cases, crank, pistons, rods, gearbox, complete clutch, barrel, complete cylinder head, ab baffle plate, water pump delete, starter motor, engine casings, some other bits I can't remember
Used race 421 headers and silencer. Ab headers have had the balance pipes removed at some point. Bit rough round edges but top system and fine for track/race. With some work/mods would be pukka for road also.
New Ab billet swirl pot and blade pump.
Deposit taken
There's a couple more pics in my archive, but can take and email more if wanted
[Edited on 6/6/18 by Flick]
dilley
posted on 6/6/18 at 03:43 PM Reply With Quote
You have u2u
dilley
posted on 6/6/18 at 05:50 PM Reply With Quote
£3000? Can send deposit now and collect next week.
