Author: Subject: Replacing an 085 battery with an 063
chrisbmxr
posted on 6/7/18 at 08:36 AM Reply With Quote
I need a new battery for my MK Indy (919cc Blade) as mine has died, but nowhere near me has an 085 type with the square terminals in stock.
One place has suggested an 063 type battery with a square terminal conversion kit on it.
Would this work OK? I'm rubbish with batteries! Just want to check it will be OK before I pay what will undoubtedly be over the odds for a battery!
Thanks.
CosKev3
posted on 6/7/18 at 08:50 AM Reply With Quote
Not an expert on battery sizes from the numbers you quote,but basically those two are the same physical size battery?
As that's the only concern on a kit car,will it fit in your current holder/box/position?
[Edited on 6/7/18 by CosKev3]
HowardB
posted on 6/7/18 at 09:09 AM Reply With Quote
for those with a BEC,
this may be of interest
Bike battery laws
strange world we live in
Howard
chrisbmxr
posted on 6/7/18 at 09:21 AM Reply With Quote
Isn't it just!
Thanks, but I'm gonna stick with a car type battery anyway.
adithorp
posted on 6/7/18 at 09:34 AM Reply With Quote
Yes it'll work fine with converter terminals and dimensions of those 2 are the same.
Flag terminal batteries have virtually disapeared on tintops so little stock available generally.
http://jpsc.org.uk/forum/
posted on 6/7/18 at 10:00 AM Reply With Quote
I went through a similar route, from flat Ford-style terminals to the normal round posts. I found it easier to replace the car's connectors entirely - the end result is far more reliable than trying to use a converter kit, which would result in one more electrical junction to corrode and fail.
It's short-term faff to swap the connectors, but much more reliable afterwards. I used good-quality snap-on/off connectors that mean that I can connect or disconnect the battery in seconds, which is very useful when I've fiddling with the car's electrics.
40inches
posted on 6/7/18 at 10:12 AM Reply With Quote
Same here,very handy
[Edited on 6-7-18 by 40inches]
JeffHs
posted on 6/7/18 at 08:18 PM Reply With Quote
I've bought my last 2 batteries online, delivered. Check for deals
miskit
posted on 6/7/18 at 09:55 PM Reply With Quote
I use an Oddessy PC680 to start and run the 1.8 MX5 engine. So small I built it into the electrical box - clamp the lid on and nice and water resistant for the 'rail
Got it from Tayna.co.uk
chrisbmxr
posted on 6/7/18 at 10:06 PM Reply With Quote
So, I bought the 063 from the motor factors down the road and they threw in the adapters. Fitted it. Went to my MOT this afternoon and the car passed!!!!
Success!
I am planning to convert the cars wiring to the snap on connectors. Thanks everyone for your help!
Chris.
