Author: Subject: Wide Track Steering Rack
mattpilmoor
posted on 18/1/05 at 09:35 AM Reply With Quote
Hi
What's the best steering rack to use? I'm using a wide track cortina rear axle.
I'd quite like to widen the track at the front but am unsure about a steering rack to match up to the cortina uprights.
Any help appreciated.
Matt
Measure twice - Cut once - Still f*!K it up!
James
posted on 18/1/05 at 10:28 AM Reply With Quote
I'd stick with the standard length front wishbones. You know they work (geometry wise) and Jon Ison and Jasper have proved that that they work with a Cortina back axle.
HTH,
James
posted on 18/1/05 at 10:32 AM Reply With Quote
Book Escort rack is a too wide between the inner joints ----- if you go wide track all you need is track rod extenders.
mattpilmoor
posted on 18/1/05 at 10:53 AM Reply With Quote
I'll go with (castor corrected) book wishbones then.
Matt
