Author: Subject: IVA Harness Extensions
K19
posted on 21/8/18 at 11:06 PM Reply With Quote
So the mounting points on my roll cage are quite far back, and as such the shoulder straps aren't as long as i'd like.
If you have the seat all the way back then the lap belt is just about in your lap, if you are shorter though, it ends up around your stomach.
Question 1: Will it pass IVA as it is? (I'm happy with it as I need the seat all the way back - but assuming it would be failed on this)
Question 2: Will using this: Harness Extender be acceptable to use to lengthen the straps, or would this be a fail.
I'd rather not have to purchase new harnesses or have to weld new mounting points on the rollcage, but I'm not sure what is allowed.
Any advice?
I have no idea what I'm doing.
MikeR
posted on 22/8/18 at 06:52 AM Reply With Quote
I'm assuming you'd need four. Have you spoken to the harness manufacturers? They may be able to sell you a longer to section cheaper than a full harness
40inches
posted on 22/8/18 at 08:34 AM Reply With Quote
The seatbelt checked at my IVA done as the seat was set, not moved on the slider. I assume set up for me, being the driver?
K19
posted on 22/8/18 at 12:15 PM Reply With Quote
Not yet, I'll ring up and ask. I'd probably only need 2 as the passenger seat is fixed. Saloon Car harnesses have longer shoulder straps, but once again would need to ask if I can get just the the shoulder sections.
K19
Hopefully then I'm just worrying about something that is a non-issue then
Mr Whippy
posted on 22/8/18 at 12:26 PM Reply With Quote
or just lock the seat position, doesn't have to be adjustable
K19
posted on 22/8/18 at 12:32 PM Reply With Quote
Drivers must be adjustable according to the IVA manual, Passenger doesn't (and isn't for me)
40inches
posted on 22/8/18 at 01:21 PM Reply With Quote
That must be new
K19
posted on 22/8/18 at 01:24 PM Reply With Quote
That must be new
No I'm just wrong, double checked - It just says that if it is adjustable, it must be in the rearmost position (which works for me )
jester
Contributor
Posts 174
Registered 21/5/17
Member Is Offline
Photo Archive Go!
Building: brought Jester.building a Jester own a Striker
posted on 31/8/18 at 03:46 PM Reply With Quote
That must be new
That's good news. See your last post I was like What!!!!! mine are both fixed
