Jonb_5
| posted on 19/10/18 at 09:15 PM |
MX5 Donor Electrics
I wondered if there is anyone who might know their way round an MX5, specifically the wiring I am using on my build and a couple of missing wires I
think I have.
I've got pictures etc I can post up so thought I'd ask.
Jon
ste
| posted on 19/10/18 at 09:23 PM |
What car was it from? I have the wiring diagrams somewhere depending on model
Jonb_5
| posted on 19/10/18 at 09:31 PM |
It was a 2003 MK 2.5 I believe.
andrew.carwithen
| posted on 20/10/18 at 07:34 AM |
We recommend using the donor MX-5 loom on our ANC Replicar kits - so may be able to help. All the wiring diags are available in the Haynes manual - so
if you post pics of the area/system you think is missing the necessary wiring, then I should be able to identify it.
Jonb_5
| posted on 20/10/18 at 08:57 AM |
That's great thank you. I have a few questions so will just post them up separately.
on the main battery feed from the battery about a foot away there is a connector, what is this for??
https://www.dropbox.com/s/sprs4mhbg1ur64v/20181019_191509.jpg?dl=0
Jon
Jonb_5
| posted on 20/10/18 at 10:01 AM |
The second question is the earth cable, it connects to the body and then extends further along and I assume connects to the body els3where but am just
worried it should connect to something rather than just the body.
https://www.dropbox.com/s/x0dpt6n4ps2yf48/20181019_191528.jpg?dl=0
andrew.carwithen
| posted on 20/10/18 at 10:17 AM |
Ref 1st question: I'm away from unit til Monday and so will check our demonstrator and Haynes manual then should you not get a reply in
meantime.
Ref 2nd question:The negative cable would have gone from the battery to the Mx-5's powerplant frame (the alloy spine that connects the diff to
the gearbox) using the broken - off connector in your pic - and also tee'd off to the Mx-5's body with the other connector in your pic.
Jonb_5
| posted on 21/10/18 at 01:55 PM |
Hi, that's great thank you.
Last question I hope but I think it's the dumbest one. In the pictures you can see the main fuse box and a 3 pin connector which goes into the
underside. I have snipped the red wire which i am pretty sure is a feed and probably why the injectors are not firing. Can anyone tell me what
it's for and also where to re-instate it from?
https://www.dropbox.com/s/kgpmdd933p05ztx/20181019_190434.jpg?dl=0
https://www.dropbox.com/s/qfop2b26crjo4do/20181019_190511.jpg?dl=0
