Author: Subject: Oil Changes every year?
RichN
posted on 24/10/18 at 07:33 PM Reply With Quote
I have always changed the engine oil and filter every year on my Riot. However I've been wondering if it is absolutely necessary given that I only do c.1000 miles a year.
I would normally do it at this time of year, before its winter hibernation, but the oil still looks like new.
What do you all do?
CosKev3
posted on 24/10/18 at 07:55 PM Reply With Quote
I would say you've been changing it at the wrong time of the year!
Fresh oil and filter after the winter,ready for using the car
For the cost I would say keep doing it yearly,sitting over winter you can get moisture in the oil,and if you start the car up over winter and it doesn't get up to full temp the moisture in the oil/crankcase doesn't evaporate.
coyoteboy
posted on 24/10/18 at 09:05 PM Reply With Quote
Think you're all missing the point, you're not doing enough miles
Report your local potholes, it actually works!
coyoteboy
PAUL FISHER
posted on 24/10/18 at 09:33 PM Reply With Quote
Modern synthetic oils it's not required, you wasting your money in my opinion, modern synthetic oils last at least 20000, even if your doing very low mileage every 3 or 4 years will be fine
fregis
posted on 25/10/18 at 04:07 AM Reply With Quote
i change oil 600-1000 miles, i don't look to kmh, just hear the engine. engine will tell you then to change - sound, pressure. Time also depends driving style.
Theoretical modern oil change 20K, but is buslhit. I was in laboratory where they do tests, they comfirm, almost all "20k oils" getting worse from 10K, marketing trick
Never be afraid to do what you are insolvent, remember: amateurs built the ark - Professionals built the Titanic.
steve m
posted on 25/10/18 at 09:55 AM Reply With Quote
I don't bother, as owning a xflow, means just toppimg up every week, has the same effect
Seriously, I do mine every year, regardless, and my tintop every 5k
posted on 25/10/18 at 10:06 AM Reply With Quote
Change the oil and filter annually just before you put the car back on the road after winter.
As said above the oil will gather moisture and replacing the oil and filter does no harm.
Oil and filters don't cost a fortune either!
Mr Whippy
posted on 25/10/18 at 11:28 AM Reply With Quote
Might be worth looking at why you do only 1000 miles a year
Lack of weather protection? is it even the right kind of car to suit your circumstances? when you add the cost of MOT, insurance, road tax & fuel for so few miles it's probably working out very expensive for what you getting out it...
Maybe a sporty production car say an little MX5 would get much more use and be almost as much fun
Just a suggestion.....
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
posted on 25/10/18 at 11:33 AM Reply With Quote
Fair comments.
After building my MK Indy we ended up with 3 kids (1 + twins). Ultimately a 2 seat car with no weather protection just didn't make sense or get used enough so I sold it on. A couple of years later I acquired a 205 GTI. SWMBO wasn't overly impressed at first, but 5 seats and a roof meant we could all get in at the same time. She came around to my thinking pretty easily after that
[Edited on 25/10/18 by nick205]
Irony
posted on 25/10/18 at 12:37 PM Reply With Quote
Seems that everyone has a different opinion on the oil change thing. Personally as long as long as the car is run up to temp every month or so during the winter I think you'll be fine changing at the manufacturers recommended intervals.
Are some of you saying then that oil has a shelf life of less than a year? Because I very very much doubt it. How is it going to absorb water once its in the sealed oil system? From the exhaust valves?
Wow you can tell you car needs a oil change from the engine sound?
RichN
posted on 25/10/18 at 01:34 PM Reply With Quote
Thanks for the pointers here. I don't think that there is a clear conclusion, but I will probably change it before it goes back on the road next year.
posted on 25/10/18 at 05:16 PM Reply With Quote
Where is this moisture coming from, the engine lubrication system on cars is more or less closed, I can't see it being a problem unless the car is parked in a swimming pool. And in any case, running the engine for a while once it is up to temperature should clear any moisture.... Although as it cools down, any water vapour will condense.
As for oil going off, it was underground for millions of year, a couple more years ain't gonna make any difference.
Personally Im in the camp of you are wasting time and money.
5 years or 6k miles should be fine.
It'd be interesting to see if they have been any investigationd into this and the results/recommendations
ReMan
posted on 25/10/18 at 07:27 PM Reply With Quote
Agreed. Im much to stingy to Chang that often 5k 5 years for me. Do let it go for more than 6 months without starting it!
www.plusnine.co.uk
∙،. ˘≈ﺣ
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ReMan 's ICQ status
RichN
posted on 26/10/18 at 11:26 AM Reply With Quote
I don't use mine over the winter and it just sits in the garage under a cover usually for 5 months.
