Author: Subject: live axle BEC Diff ratio
mattpilmoor
posted on 20/1/05 at 03:52 PM Reply With Quote
What's the best live axle/ diff combination to go for. I'd like my diff ratio to be as low as possible (3.4:1 - 3:1). I'm not sure what range of ratios are available in the cortinas/capris.
Any help appreciated.
Matt
Measure twice - Cut once - Still f*!K it up!
stevebubs
posted on 20/1/05 at 03:53 PM Reply With Quote
You should be able to get a Capri axle with a ratio around 3.3:1
Escort lowest ratio is 3.54:1
posted on 20/1/05 at 05:40 PM Reply With Quote
I think the tag on my Capri axle was 3.44:1. It disapperared while I was cleaning it up though.
Jon Ison
posted on 20/1/05 at 06:13 PM Reply With Quote
i ran 3.89 on a blade, 15" wheels.
ChrisGamlin
posted on 20/1/05 at 10:09 PM Reply With Quote
As others said, 3.54 is the highest you'll get in an English (Escort Mk2) axle. This is fine I would say, with a blade it gives you around 125mph top end with 185/60 13 tyres which is plenty even for 95% of track use. The only time youd want higher gearing is for long journeys on the motorway or if you are fitting a ZX9 which is a fair bit lower geared.
Personally I think the Capri axle is a bit big and heavy for a BEC, and its wider too so may cause issues if you're building to book
Chris
[Edited on 20/1/05 by ChrisGamlin]
mattpilmoor
posted on 21/1/05 at 02:10 PM Reply With Quote
Cheers guys.
Bob C
posted on 21/1/05 at 03:52 PM Reply With Quote
with a 3.14:1 diff on an R1 engine I'm geared for about 64 in 1st, 150 odd top.
The high 1st will make crawling in traffic a pain & limits 1st gear acceleration to ~0.8g, but I figure that should reduce wheelspin & give ~7krev cruise at motorway speed.
Bob
