number-1
posted on 3/2/19 at 02:17 PM |
Garage renting?
Where do people look to rent garages with power? All of the local authority ones are single pre fab with no power. Is there a forum or particular
place to look?
Dick Axtell
posted on 3/2/19 at 04:04 PM |
Invest in a good, Honda-powered generator. Remember to keep nearby neighbours sweet.
steve m
posted on 3/2/19 at 04:31 PM |
Pekwah1 managed to build two Strikers in his non powered garage, that was in a block of about 30 garages, and quite a distance from his house, so he
didn't use a long extension cable
steve
jossey
posted on 3/2/19 at 04:38 PM |
I found a few caravan stores have covered storage with power for trailers etc
David Johnson
posted on 3/2/19 at 04:40 PM |
It’s possible to use rechargeable or even a large car battery powered lighting , a generator is a possibility but if you intend welding you will need
a suitable genny. The mig welding forum has loads of info on suitable systems.
Mr Whippy
posted on 4/2/19 at 07:09 AM |
do you have enough land to build a garage? in the long run it would probably be cheaper than renting one for what may be a very long time. Even a
wooden structure would be fine or buy one second hand i.e. a big shed
Paul TVR
posted on 30/4/19 at 12:43 PM |
I built my GBS in a housing authority garage, had some LED lights running off a 12v battery, also a pair of leisure battery's on a 24 to 240v
inverter, enough to run a pillar drill, grinders etc.
It wasn't too bad really and was the only option if I wanted go ahead with the build.
number-1
posted on 30/4/19 at 04:09 PM |
Paul, what sort of LED lights do you use and roughly how long do you think the battery would last before charging again?
N1
