Author: Subject: Cycle wing removal help
ste
posted on 20/3/19 at 09:26 AM Reply With Quote
Best way to remove bonded on cycle wings that the previous owner bonded in wonky?
Thanks 😂
posted on 20/3/19 at 09:34 AM Reply With Quote
A little warmth (SWMBOs hair dryer has done me well) to soften the donding and a decent paint scraper to gently open a gap.
Go slowly and gently to avoid damage and it isn't too difficult to do. Go at it too fast and you risk cracking the GRP.
jps
posted on 20/3/19 at 09:36 AM Reply With Quote
Thanks 😂
If it's just been sikaflexed on the backside you could slide a thin wire (e.g. top 'E' guitar string) and use it like cheesewire to cut through?
If it's been fibreglassed in I would have thought a dremel with a little angle grinder disc would be a good bet?
ste
posted on 20/3/19 at 09:37 AM Reply With Quote
Just Sikaflexed on so I will give the cheese wire and warmth method a shot. Thanks again
gaz_gaz
posted on 20/3/19 at 09:42 AM Reply With Quote
If it's on with a PU adhesive such as tiger seal or sikaflex you'll need to get cheese wire in and cut through it then spend an age removing the residue. Heat won't help a great deal. I bonded some rear arch protectors on that moved while curing. what a nightmare removing them was.
westf27
posted on 20/3/19 at 12:10 PM Reply With Quote
Thanks 😂
g string would be my choice
555
Slater
posted on 21/3/19 at 01:03 PM Reply With Quote
MIG wire garotte, use like a cheese wire as above.
Mr Whippy
posted on 21/3/19 at 02:13 PM Reply With Quote
Chainsaw.... will take mere seconds
jps
posted on 21/3/19 at 02:33 PM Reply With Quote
Good point - stiffer so easier to push through the sikaflex to get started if necessary
Slater
posted on 21/3/19 at 06:28 PM Reply With Quote
now that made me laugh.
steve m
posted on 21/3/19 at 07:23 PM Reply With Quote
Just leave them on the car, and do a few hundred miles, they will soon fall off,
