Dangle_kt
posted on 9/4/19 at 10:26 AM |
CNC Machining - suggestions
Hi folks,
I sold the locost I built a fair few years ago, but I still pop on here now again and dream about the FOR SALE section.
Over the last few years I have setup a company to manufacture low volume, high quality motorcycle parts in the UK. I've invested a lot in
getting set up with some quality equipment and it's going well, and I'm looking to expand into other areas of motorsport.
I machine parts using a HAAS CNC Mill and CNC Lathe, and would be interested at going back to my roots and making some parts for kit cars - not
looking to get into fabrication or anything, but interested in making billet aluminium parts for kits, or accessories.
So, I'm curious, do you have any products you wished someone made?
A few that spring to mind from when I was building my car, such as gear levers, paddles, light mounts/risers, mirror mounts - the idea being is they
would be bespoke enough to just bolt on, but standard enough so they aren't all one offs.
I'd welcome your thoughts
posted on 9/4/19 at 03:27 PM |
A panel to mount toggle switches with protection inbetween the switches to pass the IVA inspection.
hughpinder
posted on 10/4/19 at 07:21 AM |
I think there are some bits required for a 'midlana' build that need turned ends to fit suspension tubes, suspension mounts and the like
which might be possible - I will send some sketches of the sort of thing, if you are interested.
Angel Acevedo
posted on 10/4/19 at 12:53 PM |
Tie Rod Extensions (track Rod ?)
Here in Mexico I had to get my Wishbone end tubes however they are called turned as I couldn´t find suitable steel tube.
PU or Delrin Bushes?
Hope this helps.
posted on 10/4/19 at 02:04 PM |
Spacers for people using Rose joints instead of bushes.
Dangle_kt
posted on 11/4/19 at 10:52 AM |
Thanks guys, the toggle switch is interesting, do the little loops not work for folk?
Delrin and aluminium are all straight forward.
Thanks!
posted on 11/4/19 at 03:08 PM |
The little loops must work, I've seen people use them and IIRC BMW Mini's have them as well.
You might be able to be more inventive with shapes if you're CNC'ing from a bit of Aluminium bar though. You could even anodise them too.
