Author: Subject: Fury Drive Shafts
BLing
posted on 23/4/19 at 05:12 PM Reply With Quote
Fury Drive Shafts
Hi all,
My Fury has a Sierra diff with push in shafts, there seems a lot of play in most of the 4 shaft joints with one being worse than the others. I'm hoping not all are toast! How much play/backlash is acceptable?
If is was a newer standard car I'd definitely replace both shafts but I'm sure I read somewhere that the tripod Sierra shafts can have some play in them? I'm just after some idea of what's normal before I start pulling things apartÖ
Brian
snapper
posted on 24/4/19 at 08:28 AM Reply With Quote
Having just rebuilt drum brakes on my 7 replica I can say there is quite a lot of backlash at the drum, perhaps 10 to 15 degrees
I eat to survive
I drink to forget
posted on 24/4/19 at 08:50 AM Reply With Quote
Ditto.
Also remember that the shaft section isn't fixed in place, it's effectively floating inbetween the ends of the driveshaft. If you fully dismantle the driveshaft there's a small spring eirther end between the end of the shaft and the lump of the CV joint.
Item 12 in the image on the site http://www.super7thheaven.co.uk/images/sierra-rear-diff.gif
BLing
posted on 24/4/19 at 11:13 AM Reply With Quote
Thanks guys,
It may well just be the single outer joint that's stuffed then. I'm getting a lot of noise on the overrun or on light throttle opening from that side of the car.
Just18972
posted on 25/4/19 at 07:56 PM Reply With Quote
Shafts
I have a pair of fitted but unused push in shafts if you need some I fitted them and they just sat there, Iíve changed to bolt in shafts so not needed and Iím pretty local.
BLing
posted on 25/4/19 at 08:39 PM Reply With Quote
Thanks, that would be great!
I'll get the faulty one off the car for a better look and send you a U2. I'm sure I can supply some beer tokens
Just18972
posted on 26/4/19 at 06:42 PM Reply With Quote
No problem mate
jimgiblett
posted on 9/5/19 at 12:01 PM Reply With Quote
Ditto.
Anyone know what item 14 is in the picture. It looks like a spacer of some type?
Jim
adithorp
posted on 9/5/19 at 12:28 PM Reply With Quote
Think that's the circlip that secures the spider to the shaft (though it's a poor bit of drawing if it is)
http://jpsc.org.uk/forum/
jimgiblett
posted on 9/5/19 at 12:32 PM Reply With Quote
Yes there was a circlip. Was worried I had missed something when I reassembled 👍
BLing
posted on 12/5/19 at 06:11 PM Reply With Quote
So I've got the shaft out and apart. It looks like the shafts were provided exchange as part of the kit in around 2003. Sods law the one hard bit to replace is the part with a problem. The splines on one end of the custom shaft have failed, there's not a lot of spline left...
I'm going to see if Berrisford can give me a quote for new one, the other option is to have a standard one shortened. A local firm J. W. Engineering said they shorten shafts for drift cars so should be strong enough.
Has anyone any recommendations? Or an old shaft laying around? The ones I have are around 24mm OD with 28 splines outer and 26 spline inner. As long as the main shaft is in good condition I don't really need the other bits.
If not it's eBay time :-)
Thanks,
Brian
