nick9one1
posted on 16/7/19 at 07:55 PM |
reverse gear on output shaft
Due to my build being rear engined and RWD, I have no space for a reverse gear on the main driveshaft - The diff is bolted directly to the engine.
Would there be any harm in having the reverse drive powering one of the driveshafts directly?
russbost
posted on 17/7/19 at 07:08 AM |
Can't see any reason why it would present a problem, I've driven a few vehicles over the years with just one rear wheel being driven
instead of both, it doesn't feel very much different, so for reverse to satisfy IVA should be fine
minitici
posted on 17/7/19 at 07:35 AM |
Gearing may be a problem as you will not have the reduction of the differential if you fit a gear directly to the drive shaft.
russbost
posted on 17/7/19 at 07:49 AM |
Reverse on the Furore (& other chain driven cars) is after the diff reduction, ie direct to the "axle", whether it drives one shaft or
both isn't going to make any difference. It does require a fair diameter of driven gear, but I'm only using a standard Toyota starter
motor to drive it
minitici
posted on 17/7/19 at 01:26 PM |
motor to drive it
OP sounds like he is driving into a conventional differential - would be best if he could fit a gear onto the input flange of the differential.
nick9one1
posted on 17/7/19 at 01:51 PM |
I'm using a zzr1100 engine and a freelander diff.
Unfortunately, there is no room at all between the diff and engine.
[Edited on 17/7/19 by nick9one1]
Dingz
posted on 17/7/19 at 04:01 PM |
How about one of those caravan movers rubbing on a back wheel, would that be allowed? If you had room.
went on and on.
russbost
posted on 17/7/19 at 04:13 PM |
motor to drive it
Doesn't matter how he's driving the diff, my point was that driving just one shaft isn't a problem, I only gave the example of the
chain drive diff as they have no reduction with the reverse sprocket directly on the axle
nick9one1
posted on 18/7/19 at 02:31 PM |
thanks for the replies.
I'll go ahead with the single driveshaft driven reverse.
nick9one1
