Author: Subject: Brake pipe - help
pewe
posted on 12/8/19 at 10:13 AM Reply With Quote
Brake pipe - help
Whilst replacing the FL caliper on the 5 Series i went to re-new the flexi only to find that the union on the steel pipe heading into it wouldn't undo to the extent it's twisting the pipe. That's despite spraying penetrating oil up into and around the join.
Car's only(!) 9 years old and corrosion free.
Any suggestions as to how I can release it short of knackering the steel pipe with grips and having to replace it?
Heat probably not an option...
TIA.Cheers, Pewe10
theconrodkid
posted on 12/8/19 at 10:18 AM Reply With Quote
spanner on the union and one on the flexi is all i can recomend....unless you can get some heat in there
who cares who wins
pass the pork pies
voucht
Contributor
Posts 246
Registered 22/5/11
Member Is Offline
Photo Archive Go!
Building: Haynes roadster on the road since november 2014 bu
posted on 12/8/19 at 10:28 AM Reply With Quote
I would try locking pliers in the steel pipe, tight enough so it doesn't twist, and not tight enough to crush it.
Steel pipes are pretty hard, so they are more unlikely to be crushed than copper ones.
An then a spanner on the union.
Hope that can help
https://vouchtroadster.blogspot.com/
https://vouchtcaferacer.blogspot.com/
johnemms
posted on 12/8/19 at 10:33 AM Reply With Quote
You don't rotate the steel pipe or it will shear off - you rotate the flexi pipe
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
pewe
posted on 12/8/19 at 10:50 AM Reply With Quote
Thanks for the replies.
Problem is the flexi has star shaped flanges which fit into the mounting bracket so nothing to purchase on there.
I just managed to avert disaster as the steel pipe was twisting as I applied force to the union.
I suppose locking pliers on the steel pipe could be the answer - the union will either undo or fook the pipe in which case I'll be replacing it anyway
Very reluctant to try flame heat, Conrod - though maybe use a big ass soldering iron?
Cheers, Pewe10
theconrodkid
posted on 12/8/19 at 02:06 PM Reply With Quote
i seem to remember the fixing you mention, is the flexi not held into it,s fixing with a clip ?
who cares who wins
pass the pork pies
pewe
posted on 12/8/19 at 03:14 PM Reply With Quote
Good point I'll have a look at it when I can be arsed to take the wheel off for the umpty tumph time...
