furryeggs
posted on 25/10/19 at 08:20 PM |
FS... ST/blacktop turbo engine.
I’ve been building this engine for a few months with the hope of fitting in my Tiger, but It’s going to be a lot tighter than thought. I’m going to
stick to NA and do tge cams and head instead.
Engine spec as follows... and cost so far
ST170 bottom end (complete engine 90k). £250
ARP rod bolts. £90 (burtons)
Cometic 1.8mm head gasket £120 (burtons)
Blacktop head (bigwasa spec)
ST170 inlet valves
Rover T16 inlet manifold inc 380cc injectors stripped cleaned and HTemp painted £165
Danst adaptor T16 plate. £60
Volvo TD04 15G HL turbo. £85
new Turbo seals, bearings and impeller. £65
turbo log manifold £40 (diy)
Custom shortened aluminium bottom sump inc plug and oil return. £30 on bits (+moded steal sump)
New oil pressure sender. £10
New Front and rear crank seals. £35
Plus a few little bits laying around, over £800 spent so far but most of it’s there, timing belt is fairly new but I would change it along with maybe
a new water pump.
open to offers but would want as close to my costs as possible... Pictures to follow asap.
furryeggs
posted on 25/10/19 at 08:56 PM |
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
furryeggs
posted on 26/10/19 at 08:26 PM |
Deposit taken
Robbaa
posted on 29/10/19 at 01:04 PM |
happy to take this if the deal falls through
