Nickp
| posted on 29/10/19 at 06:34 AM |
Jag IRS dimensions?
Anyone got a Jag diff sat about (or in a car) that they can measure up please?
I'm after the total width of the diff including the discs if possible?
Thanks in advance,
Nick
r1_pete
| posted on 30/10/19 at 09:14 AM |
They are 451mm between uj centres if that helps?
Nickp
| posted on 30/10/19 at 11:09 AM |
The UJ centre either side of the diff?
Where did you get that info please?
r1_pete
| posted on 30/10/19 at 01:48 PM |
Yes, the uj yokes which bolt on with the discs.....
Believe it or not its something I remember from my 70s /80s hot rodding days, building irs crossmembers, and working out the suspension angles.
r1_pete
| posted on 30/10/19 at 02:04 PM |
Found on the net, looking at the dims this is an XJ6 axle,
Nickp
| posted on 30/10/19 at 02:47 PM |
Cheers that's a really helpful diagram and good memory sir!!
What I'm doing is looking to fit a Jag diff into my old Lotus Eclat, which is getting a Lexus V8. The original Salisbury axle / diff is not
renowned for it's strength and the ratios are rubbish for the V8 too, either 3.7 or 4.1, I have the 4.1 unfortunately I'm hoping to
retain the Lotus suspension / hubs etc, just replace the diff. The original width of the UJ centres is 26.75" on the Lotus. According to your
diagram the Jag is 17.75, leaving me with a 9" shortfall. My initial idea was to get a pair of spacer / adaptors machined up for either side so
they bolt to the discs on the Jag diff and the Lotus shaft bolts to them. I was hoping that the spacers would be smaller than this tbh.
r1_pete
| posted on 30/10/19 at 04:03 PM |
Mmmm, the Jag diff is phenomenally heavy, the halfshafts also serve as the top wishbones so there is a lot of strength and weight built into the diff
casting.
It might be worth looking at some of the big Triumph diffs, 2500pi, TR6 etc...
Nickp
| posted on 30/10/19 at 05:08 PM |
casting.
The Lotus is the same, using the driveshaft as the top wishbone and has inboard brakes, hence my thinking behind using the Jag diff.
Just weighed the Lotus axle / diff assembly and it's a full 50kg!! Is a Jag diff and brakes as much as that?
If I can get it mounted in there then I'll need to work out if it's best to use a spacer bolted to the disc or make extended driveshafts.
The latter will move the pivot point of the 'top wishbone' (driveshaft) in by 4.5" affecting suspension geometry but a better
solution than a spacer I reckon.
Simon
| posted on 30/10/19 at 08:23 PM |
I was looking into using Jag IRS on toy car years ago and I'm sure the diff alone was 47kg. For better ratios I went to BMW and got a 2.28:1
shipped from Germany for £150. Never fitted it as sold car to pay for extension.
Anyway, found this thread which I'd recommend reading
http://locostbuilders.co.uk/viewthread.php?tid=48585
