Shooter63
posted on 31/12/19 at 02:36 PM |
AGM battery charger
I've just fitted the above to the kit car, what type of charger do I need to A re-charge it after turning the engine over to bring the oil
pressure up ( new built engine) B keep the battery topped up as no doubt the car will sit around A lot not being used.
Shooter
NigeEss
posted on 31/12/19 at 03:38 PM |
I use one of these:
Ring 12a charger
Works well and has AGM setting.
tims31
posted on 1/1/20 at 05:15 PM |
I have one of these which I put on mine over the winter or if the car will not be used for a period of time. Charges the battery and also maintains,
has a plug installed on a lead which is permanently attached to the terminals so is easy to just plug into the charger.
CTEK charger
I have one of the Odyssey PC680 batteries which is AGM and 16Ah. This charger is good for batteries up to 32Ah
[Edited on 1/1/20 by tims31]
Build: http://www.martinsfurybuild.co.uk/
Shooter63
posted on 2/1/20 at 06:33 PM |
Cheers lads , all sorted and ordered
Shooter
posted on 2/1/20 at 08:44 PM |
For info any smart battery charger with a winter mode will charge an AGM to the correct (higher) voltage which is up to 14.8volts.
For a good reasonably price smart charger with a wide selection of modes look at the Maypole MP4
MP4 on Amazon
