ch1ef
posted on 1/2/20 at 09:27 PM |
Gearshifter solution for Zetec 6 speed getrag, extra long cables?
Not sure if there as an easier solution? My Car has a Zetec with a getrag 6 speed box. Is there a custom shifter to reverse the gear lever action, to
then run cables to the box as normal, or do I need to run extra long cables so they one in from the front of the shifter as it would be in the FWD
setup? What is the norm without making a custom shifter?
Thanks for any help
ianhurley20
posted on 1/2/20 at 09:36 PM |
I was going to build a Midlana and had some cables from an MG F with the Ford gear lever which seemed to fit the bill. That said after my Haynes
accident the Midlana project was shelved so can't confirm its operation
