Chaz
posted on 10/5/20 at 06:59 AM |
Modify from original SVA/IVA
Hi all, how far can you modify your car after registration?
I have an MK indy and wondering if you change the engine do you need to re register/re-IVA etc what are the rules? I looked on the gov website but not
sure I'm in the right place.
I'm sure this has been asked before but I've been out of the game for a while and now I'm back - thank you lockdown!
kingster996
posted on 10/5/20 at 07:18 AM |
Yep. I changed mine. Plenty of others have too.
Not sure what happens with emissions though as I am lucky enough to have a Q plate so they don’t come into the equation at mot time.
I used to be indecisive, but now I'm not so sure
posted on 10/5/20 at 07:26 AM |
Modify after SVA/IVA? Shock horror!
peter030371
posted on 10/5/20 at 08:30 AM |
No need for a re-test but you will need to inform DVLA of the new engine number and capacity. If the change in capacity changes the tax group they
will probably want to see some evidence such us engine receipt and garage report but the are not difficult to sort out.
As already said if a Q plate emissions are no problem but if your car is non-Q then the emissions will be tested as per the levels you are already
tested to at the MOT.
adithorp
posted on 10/5/20 at 09:21 AM |
As said by others, engine change just need reporting to DVLA. If the capacity changes then the tax might (above below 1500cc) and they might ask for
an engineer's report to confirm the change. Emmision limits stay at whatever they were at IVA.
As for any other changes, knock yourself out. Theoretically, any significant change to chassis design would need a new IVA but nothing else. In
practice, seeing as there's no record of the design at IVA who's to know what's changed?
http://jpsc.org.uk/forum/
snapper
posted on 10/5/20 at 09:59 AM |
SVA/IVA Sets the emissions for the car, if you change engine to a newer model the emissions requirement of the vehicle remains as tested. The
emissions requirements are usually printed on the front page of the V5 in the case of a non Q registration. Q registration is effectively a smoke
test.
I eat to survive
I drink to forget
Chaz
posted on 10/5/20 at 12:39 PM |
Thanks all...
So i currently have a silvertop zetec 1800 1994, i think this was before some emissions restriction - my brain forgot to remember for me!
Hyperthetically if i were to change for a bigger engine but same emissions i would be ok??
What about if I kept the zetec and modified for s/charge or turbo? Same cc but different emissions.
adithorp
posted on 10/5/20 at 12:53 PM |
Unless you put a sub 1500cc (which would reduce the tax) nothing would change other than the size and engine number on the v5.
obfripper
posted on 10/5/20 at 02:26 PM |
They have fixed the MOT manuals so if your V5 doesn't have the limits the correct limit can still be applied.
From the manual:
"Kit cars
Kit cars and amateur-built vehicles first used on or after 1 August 1998 must have either Single Vehicle Approval (SVA) or Individual Vehicle Approval
(IVA).
You must test kit cars or amateur built vehicles to the limits in the vehicle’s registration document (V5c). If the V5c does not show any limits, you
must test it to the limits of the engine fitted at the time of the SVA or IVA test."
If you're on a q plate, the emissions limits do not apply even if recorded on the V5.
Dave
mikeb
posted on 12/5/20 at 11:41 AM |
Hi all, are we still confident on the Q plate emissions? it seems they changed the MOT manual to take that into account. Or is it old school testers
just take a look at a Q and know what to do?
obfripper
posted on 12/5/20 at 12:00 PM |
It's still in the manual, same as has been for years.
"For emissions purposes only you should treat the following as first used before 1 August 1975:
kit cars and amateur-built vehicles first used before 1 August 1998
Wankel rotary-engined vehicles first used before 1 August 1987
Q plated vehicles"
Dave
StrikerChris
posted on 12/5/20 at 09:42 PM |
Not meaning to hijack, but would the same apply for a tin top? Ie bolting a 98 engine in an 85 car,both 2.0l. will this affect mot emmisions?
Chris
obfripper
posted on 12/5/20 at 09:46 PM |
Pre Sept 2002 vehicle is tested to fitted engine age, post Sept 2002 vehicle emissions limits are to date of first registration.
Dave
[Edited on 12/5/20 by obfripper]
FEZ1025
posted on 9/6/20 at 09:05 PM |
I'm not confident at all, I think all the Q plate people may have a shock next time they turn up for an MOT if the tester isn't friendly.
https://www.gov.uk/guidance/mot-inspection-manual-for-private-passenger-and-light-commercial-vehicles/8-nuisance#section-8-2-1
Q plated vehicles
Kit cars
(IVA).
So if the Kit car was first registered after 1 August 1998 whether it is on a Q plate or not, the emissions are tested on what is on the V5C &
shown to the tester at the time of the test. If they are not shown then they are tested on the age of the engine that was fitted at the tome of the
SVA/IVA.
How do I know, I had my Q plated Kit Car tested last Thursday & went through it, the kit was registered on 1/9/1999 he wanted to test it as such,
however I was able to point out that the engine fitted ceased production in 1993, so he tested it as that.
obfripper
posted on 9/6/20 at 10:00 PM |
It all comes down to the definition of first used date for mot purposes to determine the applied standards.
"When the ‘first used’ date is not known or incorrect, you should determine the vehicle’s ‘first used’ date as follows:
a. Its date of manufacture, if the vehicle was originally used without being registered in Great Britain, such as an imported vehicle or ex-HM Forces
vehicle.
b. Vehicles having a Q plate registration when presented for MOT are to be treated as follows:
-for emission purposes only, they are to be considered as first used before 1 August 1975
-for all other testing purposes, they are to be considered as being first used on 1 January 1971
c. In any other case, the earlier of either its date of first registration or the date 6 months after it was manufactured, for example, vehicles first
used before 1 September 2001 do not need to have anti-theft device. However, a vehicle first used after that date, but manufactured at least 6 months
before that date (before March 2001) would still not need an anti-theft device to be fitted.
Section b being the important one here, irrespective of iva date/registration date, the applied standards for a Q plate are for 01/71 for everything
except emissions, and pre 08/75 for emissions limits, ie visual check only.
If it's been tested to any other standard, the tester needs to go and read the manual!
If you were on an age related plate, the procedure applied would have been correct.
Dave
CosKev3
posted on 9/6/20 at 10:35 PM |
vehicle.
Dave
"When the ‘first used’ date is not known or incorrect, you should determine the vehicle’s ‘first used’ date as follows"
Where do you find the first used date,is that the registration date?
If so why should the tester use the above testing method which is for if you dont know the first used date?
obfripper
posted on 9/6/20 at 10:56 PM |
The whole purpose of a Q plate is to enable registration of a vehicle with unknown identity and first use, hence the section specifying the applicable
dates to use.
For the majority of vehicles the registration date is the first used date, the remaining vehicles fall under one of the three sections quoted.
Dave
FEZ1025
posted on 10/6/20 at 06:34 AM |
Section 8.2.1.2. Gaseous emissions
Specifically states how you should test a Kit car first used on or after 1st August 1998, it doesn't state a Kit car first used on or after 1st
August 1998 unless they are on a Q plate.
obfripper
posted on 10/6/20 at 06:56 AM |
That only applies if it is on a new or age related plate (ie a defined first use date), the appropriate section is in the introduction under first use
dates as quoted, a Q plated vehicle does not have a defined first use date.
It is one aspect of the mot that has not changed since Q plates were introduced.
Dave
peter030371
posted on 10/6/20 at 12:32 PM |
The problem is some testers think they are right, even if you point out otherwise, and they will do what they think is right even when it isn't
When you start pointing out, polity, that they must be mistaken they can get all defense and start to become little Hitlers with such comments as
'I do this all day, I know my job' and 'who do you think you are telling me I don't need to test the emissions'.
I've been there before but my current tester is very clued up and as soon as I book the car in he normally says 'ahh, Q plate this will be
quick and easy'.
FEZ1025
posted on 10/6/20 at 01:11 PM |
So you are all saying that anything with a Q plate is not a Kitcar?
peter030371
posted on 10/6/20 at 01:22 PM |
It doesn't matter if its a kitcar or not, anything with a Q plate is tested as per 'for emission purposes only, they are to be considered
-for all other testing purposes, they are to be considered as being first used on 1 January 1971' and that is regardless of when it was built or
first used.
This has been clarified by the DVLA many times before.
[Edited on 10/6/20 by peter030371]
FEZ1025
posted on 10/6/20 at 01:41 PM |
Link?
peter030371
posted on 10/6/20 at 01:59 PM |
Link?
Can't link to phone calls
FEZ1025
posted on 10/6/20 at 02:31 PM |
Link?
So you're asking me to believe some random guy on the Internet about some convenient phone calls he
may or may not have had over what I can see written in black & white, good luck with that one.
