Author: Subject: VAG aluminium rear calipers and carriers
djtom
posted on 22/6/20 at 01:55 PM Reply With Quote
One set of VAG rear aluminium calipers and carriers in excellent condition. These can be used as a replacement for the heavy Sierra calipers I believe, the 90mm hole spacing on the carrier bolts straight on to a Sierra brake mount.
These have a good handbrake mechanism. The hydraulic connection is either by a flexi (female m10x1), or if you remove the flexi bracket and pipe, you can run hard line direct to the caliper (ideal for a live axle).
As with so many things, I ended up going a different route and these arenít needed. No pads Iím afraid.
£40 plus a fiver post.
[Edited on 22/6/20 by djtom]
Al3xG
posted on 22/6/20 at 02:35 PM Reply With Quote
Interested, waiting for pics
Thanks.
MikeR
posted on 22/6/20 at 06:49 PM Reply With Quote
I could be interested. What size discs do these use? I'm wondering if they'd fit in a13"rs wheel.
djtom
posted on 22/6/20 at 09:34 PM Reply With Quote
Pics added as promised.
I believe they use the standard sierra discs.
Regarding the 13" wheels - according to a quick search herehere and here they will indeed fit under 13" wheels but may require a little bit of trimming of the fins to do so depending on exactly what wheels you have. Haven't tried it myself so can't advise I'm afraid.
Al3xG
posted on 23/6/20 at 08:14 AM Reply With Quote
I'll pass, looks like they are not a straight swap on my Westfield.
Thanks anyway
